Sponsored by: Innova
NAV mp3's playing
Old Feb 17, 2013 | 03:36 PM
timmyZ06's Avatar
timmyZ06
Default NAV mp3's playing
I did searched tried few things, I was wondering how you has been sucessfully burned MP3's cd's for your C6 Navi player that will actually work! All the thread i found are old. I wanted to hear something newer, i tried media monkey kinda complicated, itune? maybe still trying to figure this one out. Im not very good at it so what is the easiest software i could use to burn cd that wont stop at song 6 and wont play the other 144 songs!
thanks in advance iits for my 09 zr1 with navi
Old Feb 19, 2013 | 02:03 PM
4SUMERZ's Avatar
4SUMERZ
I use Nero Express, and burn your MP3's as a DATA CD. Works everytime for me.
Nero is a free download as well.
Good Luck
Old Feb 19, 2013 | 10:11 PM
markcz's Avatar
markcz
I have several CDs I burned from itunes. Worked in both '07 6-disc changer and '12 Nav HU.
Old Feb 20, 2013 | 05:44 AM
timmyZ06's Avatar
timmyZ06
Good Luck
burn as data and the navi hu will read it?
Used in the cd slot right? Not dvd one
Old Feb 20, 2013 | 11:02 AM
Canuck's Avatar
Canuck
Default Burning mp3's
I am interested in this thread also. I have burned mp3 CDs as data using both Nero and ImgBurn and have the problem that the player will not play beyond song 6 or song 8 even though there are approximately 50 mp3's on the CD. (It will also repeat the six or eight songs in random order.) I haven't tried using folders yet but not sure this will alter the results. If I use a standard audio CD, then the player will play all the songs. I'm not sure what to try next.
If anyone can assist with this I would appreciate any help.
Old Feb 20, 2013 | 11:16 AM
timmyZ06's Avatar
timmyZ06
Same thing here^^
Old Feb 20, 2013 | 11:48 AM
Canuck's Avatar
Canuck
I am currently charging the battery ( a trickle charger ) as the breaker went sometime during the winter. As soon as I can start and run I will try a number of things to try and resolve this. The same CD will play without problems in my Silverado. I will stay in touch.
Old Feb 20, 2013 | 12:56 PM
4SUMERZ's Avatar
4SUMERZ
Using the Nero program, once open, select Nero Express, then select Data CD. ADD (+) all your MP3's to burn. I use Memorex CD-R 700 MB 80 minute and Have made many a CD for my vette, and each and everyone has played ...all the 100 songs.
I have a 2006 vette, so if they play in my CD then it should play in the later models I would think.
Good Luck
Old Feb 20, 2013 | 01:38 PM
timmyZ06's Avatar
timmyZ06
Ill try this
Old Feb 20, 2013 | 02:30 PM
Canuck's Avatar
Canuck
LV2TOUR: Did you use any folders on your CD? I did not and as I said, I also used Nero and ImgBurn with Memorex, Verbatim and Sony CDs... did not matter. Manual says up to 500 folders , 8 deep.
'06 Z06
Old Feb 20, 2013 | 03:14 PM
timmyZ06's Avatar
timmyZ06
Good Luck
Which version of nero??
I just downloaded nero 9 for windows 7, im burning a cd right now.
Ill test it in my sierra denali which have navi, but it cant try in vette since it still in a warehouse for the winter!
Old Feb 20, 2013 | 10:53 PM
4SUMERZ's Avatar
4SUMERZ
I'm using Nero 9 for Windows 7 Home Edition. I do not use folders when burning.
Old Feb 21, 2013 | 04:40 PM
timmyZ06's Avatar
timmyZ06
I burned on with nero 9 with folder, worked great in my truck. time will tell for the vette
Old Mar 29, 2013 | 11:44 PM
duramaxsky's Avatar
duramaxsky
Old Mar 30, 2013 | 07:00 AM
timmyZ06's Avatar
timmyZ06
Still working on it, so far nero seem to be what i need
Old Apr 3, 2013 | 11:19 PM
Snake.Oiler's Avatar
Snake.Oiler
St. Jude Donor '13 thru '20,'22,'24 thru '26
Straight from the manual:
Using an MP3
MP3 Format
When creating an MP3 disc, the following is a list of guidelines.
If these guidelines are not followed while recording a CD-R(W), the CD may not play.
• ID3 tag information is displayed by the radio if it is available. The radio supports ID3 tag information v1.0 or v1.1. The radio displays a filename, song name, artist name, album name, and directory name.
Maximum 31 characters, including spaces, in a file or folder name.
• Maximum number of folders is 500 with 500 files with a maximum hierarchy of eight folders. It is recommended to keep the depth of folders to a minimum in order to keep down the complexity and confusion in trying to locate a particular folder during playback. Create a folder structure that makes it easy to find songs while driving. Organize songs by albums using one folder for each album. Each folder or album should contain 18 songs or less.
• The files can be recorded on a CD-R or CD-RW with a maximum capacity of 700MB.
• DVD with MP3 are not playable on this system.
• The radio does not play a mixed mode CD-R/RW, a disc recorded with both *.cda and *.mp3 files.
• The player supports a disc with multiple sessions, but it is not required that the disc be finalized. It is recommended to record the disc all at once.
• Recording format mode 2 or mode 2XA with Romeo or Joliet file system is not supported with this player.
• All applicable Mode 1 recording formats are supported.
• MPEG 2.5 is not supported with this player. File formats MPEG 1 and MPEG 2 with all bit rates (including variable) except less than 16kbps are supported with this player.
• Long files or folder names or a combination of a large number of files and folders could cause the player to be unable to play up to the maximum number of files or
folders or affect the reading speed and time to play.
Old Apr 4, 2013 | 09:51 AM
markcz's Avatar
markcz
That's cheating!
To NAV mp3's playing
