Sponsored by: Innova
component wiring
Old Feb 28, 2013 | 09:34 PM
c6crazy's Avatar
c6crazy
Default component wiring
My diamond audio set has crossovers with both + and - on the in and out side for both the tweeters and woofers. I know how to wire the out but not the in from the amp. I have only the front channel on amp for components.. the crossovers are both active or passive..the instructions were missing from the box.
Old Feb 28, 2013 | 09:51 PM
philip_g's Avatar
philip_g
you're using one amplifier channel to drive both the L+R components? Am I understanding that correctly? So then you need to know what the impedence of your components is and decide what load the amp can drive. Assuming they're 4ohm and the amp is two ohm stable run the +/- from the amp to one XO + to + and - to - and then a speaker wire from the + in on one XO to the + in on the other and then - to -
if I'm misunderstanding and you have two front channels you'd wire from the amp to each XO and I don't understand what the confusion is, sorry.
Old Feb 28, 2013 | 10:26 PM
c6crazy's Avatar
c6crazy
I have the front channels on the amp both L and R which gives me 2 outputs a + and - for each channel. My input on the crossover has 4 slots 2 for + and 2 for -. a set for the tweeter and a set for the woofer. So coming from the amp I do not have enough wires to fill 4 slots per channel. I think you use the center + and - for this type of setup on the crossover since I do not have a active setup but i'm not sure.
Old Feb 28, 2013 | 10:34 PM
philip_g's Avatar
philip_g
gotcha, one of the inputs should say MID or something like that. Just run the amp to that input.
Old Mar 2, 2013 | 12:29 PM
markcz's Avatar
markcz
What model speakers, look them up online before connecting it wrong.
The pics I've seen for Diamond Audio crossovers have the screws labeled on the plastic cover.
To component wiring
