Sponsored by: Innova
XM antenna
Old Apr 17, 2013 | 08:38 PM
sea six's Avatar
sea six
Default XM antenna
Has anybody had any luck with using the existing XM antenna with a new HU and the SC100 adpt? If not were have you mounted the antenna that comes with the kit?
Rod
Old Apr 17, 2013 | 09:34 PM
Fasthotrod's Avatar
Fasthotrod
I mounted my GPS antenna for my new HU inside the dash, under the center channel speaker grill/defrost vent. On the drivers side, there is a small, flat spot where the antenna fit perfectly without blocking the air flow. I ran the cable down to the HU, no problem.
Old Apr 17, 2013 | 09:45 PM
ch47d1sg's Avatar
ch47d1sg
Existing XM antenna is over rt rear wheel well? You would need to run a wire to the HU
Not worth it in my opinion, get you a XM nd mount under the dash
Old Apr 17, 2013 | 10:00 PM
sea six's Avatar
sea six
Roger that!
To XM antenna
