Sponsored by: Innova
Amp keeps shutting off
Old May 25, 2013 | 06:22 PM
markcz's Avatar
markcz
Originally Posted by PBone
When I originally installed the HU, i had it powering the speakers for a while. After I installed the 5 channel, do I need to disconnect the wires in the back of the HU that go to the speakers?
What speakers is it connected to?
It doesn't matter I guess, if you have an amp and aftermarket speakers installed then disconnect the speaker output wires.
Old May 31, 2013 | 09:39 PM
Jeffro_510's Avatar
Jeffro_510
You have the amp and the deck powering the speakers at the same time? (don't know but doesnt sound good)
Or are the wires running from the deck and just dangling inside the door? (That could be a short, or ground out)
Old Jun 1, 2013 | 09:39 AM
PBone's Avatar
PBone
Turns out this was the issue. The HU amp wires were still hooked up, and the stock wires were touching, causing it to short out.
Pulled the HU, cut the stock wires, and it works fine now!
Old Jun 1, 2013 | 11:07 AM
Jeffro_510's Avatar
Jeffro_510
well there you go, glad you found it
Old Jun 2, 2013 | 10:56 PM
Netfly's Avatar
Netfly
Check your amp to ground connection.
