Sponsored by: Innova
Amp keeps shutting off
Old May 15, 2013 | 07:17 PM
PBone's Avatar
PBone
Default Amp keeps shutting off
5 channel amp, Pioneer Nav unit, 10" sub, all new door speakers.
Everything wired up and works fine. The other day I was driving and my Amp shut off and the headunit started displaying "AMP Error". I got home and checked all the connections and had no idea what it could be.
Now it does it every time I get the car out. The amp is not going into protect mode, it's just turning off. I triple checked every connection. The part that confuses me is that there is no set amount of time before it happens. Sometimes it shuts off before I make it out of the driveway, and other times I go drive a half hour before it shuts off.
Any suggestions?? I contacted Rockford Fosgate and they said it must be a problem with the remote turn on wire being loose. Checked that and it's fine.
04 Z06 if that matters
Old May 15, 2013 | 07:23 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
Need to put a meter on the amp and see what it's doing when it shuts down amp error on head unit sounds odd to me
Old May 15, 2013 | 07:26 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
Its prob the amp...
the RF amps are not what they used to be. I have people complaining to me about them all the time and switching them out.
Old May 16, 2013 | 08:02 AM
PBone's Avatar
PBone
Originally Posted by Double D Mods
Its prob the amp...
Can you recommend a comparable 5 channel amp? I am using the Focal P25 DB sub which I purchased from you guys. Not looking to break the bank on the amp, obviously.
Old May 16, 2013 | 08:11 AM
0Double D Mods
Former Vendor
I have been selling the new Kenwood XR900.5 5 channel amp
awesome amp.
How much are you wanting to spend?
This will give me an idea of what I can get for you
Old May 16, 2013 | 11:27 AM
PBone's Avatar
PBone
awesome amp.
Well, if I have to replace this amp, I'd like to keep it under $400, preferably closer to $350 if possible.
I'm going to see if I can borrow an amp from somebody and see if that's what the problem is.
Old May 17, 2013 | 11:52 AM
crAzy's Avatar
crAzy
Dennis set me up with Pioneer GM D8601 and GM D8604 amps. Small and work perfect for my 10" Alpine Type R as well as my speakers. No complaints.
Old May 19, 2013 | 10:37 AM
PBone's Avatar
PBone
Not having any luck finding somebody to let me borrow an amp.. Looks like I'm going to have to bite the bullet and buy one which I REALLY don't want to do unless I know 100% that that's the problem :/
Old May 19, 2013 | 11:52 AM
markcz's Avatar
markcz
I wasn't even aware that a HU could do that
The only things connecting the HU to the amp are (should be) the RCA's and the trigger wire. If the HU is telling you the amp has issues, then I'd have to say either one or more of the RCA channels is shorted together inside the amp, or the trigger wire is somehow pulling way too much current and causing the HU to go into some type of self-protection mode.
You can test for the trigger over current by disconnecting the trigger wire at the amp, then install a temporary jumper from the amp B+ to trigger. That would make the HU happy, but the amp may still have issues, so keep checking it to see how hot it is.
You can test for a shorted RCA inside the amp by removing one or more from the amp, then go for a drive. I'd try removing rears, then test. If OK, reconnect rears and disconnect fronts, then test. If you get lucky you may be able to recreate the fault at will, then you can switch HU inputs to the bad amp channel to verify that it's the amp and not the HU.
Old May 19, 2013 | 08:18 PM
pentavolvo's Avatar
pentavolvo
As I mentioned Earlier a multimeter would really help
Old May 21, 2013 | 06:05 PM
PBone's Avatar
PBone
You make it sound so easy
Old May 21, 2013 | 07:44 PM
markcz's Avatar
markcz
It's a relatively simple concept, the amp is doing something the HU doesn't like, so disconnect wires between them one or two at a time to see if the problem goes away.
If you get lucky enough to isolate the issue to one of the amp RCA connections, try using a different source wire from the HU on that same input (switch front/rear) to make sure it's the amp and not the HU.
Old May 23, 2013 | 04:44 PM
PBone's Avatar
PBone
Tried this last night and didn't have any success. Still shut off no matter which RCAs were plugged in.
Pioneer emailed me back and this was their response:
Thank you for contacting Pioneer Electronics (USA) Inc.
If no speakers are connected to the speaker wires of the unit and you are getting an amp error, the unit will need service. Please click on the link below to locate a service center in your area.
http://www.pioneerelectronics.com/PUSA/Support
Sincerely,
Luana
Customer Service Representative
It's a brand new headunit... I can't imagine it needing serviced
I'm going to disconnect the external amp completely and just turn the headunit on and see what it does.
Old May 23, 2013 | 05:39 PM
pentavolvo's Avatar
pentavolvo
The speaker wires behind head unit that you aren't using are probably shorting out
Old May 23, 2013 | 07:56 PM
markcz's Avatar
markcz
Why didn't I think of that
Old May 24, 2013 | 12:41 PM
PBone's Avatar
PBone
So I should pull the headunit and check and make sure the wires aren't touching or anything?
Old May 24, 2013 | 01:03 PM
GCRoberts's Avatar
GCRoberts
I didn't read this thread too closely, so I'm probably off base. Back in the 90's I had an amp in my car that kept turning off on me and it took forever to find the problem. The installer had put in a big fancy clear case fuse holder in my engine compartment. I can't remember if it was when the engine got hot...or when I turned on the A/C....but I do recall that changes in the temperature around the fuse holder caused it to lose contact. Hence, my amp would shut down.
Just a thought....
To Amp keeps shutting off
Old May 24, 2013 | 05:00 PM
markcz's Avatar
markcz
Yes. Pull it out and separate every unused wire that's connected to the back of the HU. Cover the end of each wire with a folded over piece of tape, even if none are shorted to each other one of them may just be touching the frame.
Old May 25, 2013 | 04:13 PM
PBone's Avatar
PBone
Checked them all and didn't see any touching. Taped them off and drove it to the gym and it still shut off.
One thing I did notice though...
When I originally installed the HU, i had it powering the speakers for a while. After I installed the 5 channel, do I need to disconnect the wires in the back of the HU that go to the speakers?
Old May 25, 2013 | 04:14 PM
PBone's Avatar
PBone
Just a thought....
I'll have to check that as well. Thanks
