Sponsored by: Innova
What MultiChannel Amp?
Old Jun 27, 2002 | 01:37 AM
AP's Avatar
AP
Default What MultiChannel Amp?
Hi ...
I now have to find a all in one amp...below are my choices .... these are the only ones I can afford ... so please keep that in mind ...
Old Jun 27, 2002 | 06:08 AM
Z oooooo 6's Avatar
Z oooooo 6
Default Re: What MultiChannel Amp? (NewVetteLover)
you can afford a JL5005? Next to the Diamond Audio amp, it's probably one of the most pricey 5 channels. Here's a few to consider just in case.....
-Phoenix Gold XS6600 - I believe it's still on the market... it kicks butt, 75x4 with 300 bridgeable for the 5th and 6th channels. You can also add a sublevel control like the JL Audio amp.
-If you can get your hands on a F752 Alpine amp made with Tri Path, go for it... it's a great amp for the money.
-the new Kenwood Excelon 5 channel amp is pretty nice, and very affordable. And best of all, unlike most Japanese amps, it's powerful.
-I still think the JL Audio 5 channel amp is your choice... especially if you're not running anything too power hungry for rears. (JL has 25 x 2 at the rear, 100 x 2 at the front, 250 x 1 mono for the sub).
Btw... JL does not honor warranties on products purchased on the Internet... something to consider. You must send a receipt from an authorized dealer with every warranty problem. This is the case with almost every manufacturer
Old Jun 27, 2002 | 12:18 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: What MultiChannel Amp? (Z oooooo 6)
Of those, go with the JL audio. Phoenix Gold and soundstream may also have some you can use.
Old Jun 27, 2002 | 03:53 PM
AP's Avatar
AP
Btw... JL does not honor warranties on products purchased on the Internet... something to consider. You must send a receipt from an authorized dealer with every warranty problem. This is the case with almost very manufacturer
I am getting the items from a local shop ... and since my brother owns the building they rent ... they are hooking me up ... on the JL's price ..
Old Jun 28, 2002 | 11:05 AM
NassBlue's Avatar
NassBlue
Diamond D7 Series :D
Old Jun 29, 2002 | 03:09 AM
AP's Avatar
AP
Default Re: What MultiChannel Amp? (NassBlue)
Which particular amp model is that? I have not seen a 5+ channel Diamond Audio ... maybe I could have the shop hook me up with one of those ...
Old Jun 30, 2002 | 09:21 AM
NassBlue's Avatar
NassBlue
Diamond 7056... 6-channel amp... It ROCK'S
[Modified by NassBlue, 8:21 AM 6/30/2002]
Old Jun 30, 2002 | 11:31 PM
goofygrin's Avatar
goofygrin
I have an MTX 5400x. It is really good (never had it thermal on me and I have pushed it hard). It has a class D sub channel on it for better efficiency.
I have heard good reviews of the Hifonics 5 channel amp too (its not a super high-end brand though).
I tend to buy from www.thezeb.com and www.sounddomain.com
Sean
Old Jul 7, 2002 | 12:27 AM
Mako's Avatar
Mako
When my amp failed recently, it was replaced with a Kenwood KAC X650D. It seems to be very powerful and clean.
Old Jul 7, 2002 | 12:33 AM
ZippoMan's Avatar
ZippoMan
I have the new Kenwood Excelon 5 channel amp. It was just a little over $400 and have no complaints what-so-ever. Plus it has a fancy little LED that cycles colors as its on :yesnod:
Old Jul 7, 2002 | 02:24 AM
buddha's Avatar
buddha
Soundstream Rubicon 550-5. 3/5 channel amp. 4x80 (or 2x160) + 1x250 stable to 1 ohm. .02%thd, S/N Ratio >100db, Dampening factor >200.
$429 (was $399) at http://www.onlinecarstereo.com/carau...2&q=&start=26. You will be hard pressed to find a better multichannel amp at anywhere near that price.
Old Jul 7, 2002 | 02:33 AM
92TripleBlack
Default Re: What MultiChannel Amp? (buddha)
Old Jul 18, 2002 | 11:04 PM
AP's Avatar
AP
Default Re: What MultiChannel Amp? (92TripleBlack)
Thanks Guys ... I already bought my amp ... well 2 actually ... a JL 500/5 and 500/1
Old Jul 19, 2002 | 09:19 AM
Biohazard's Avatar
Biohazard
You Bought THE SHIZNIT!!!! I have the 5 channel in the pathy and a 300/1 in the vette....I did not want too much drain on the batt and did not want to install another battery and upgrade my alternator...did you have to?
I doubt that Iwill ever let another soul touch my MagRedII baby, within reason..... :rolleyes:
Again, wish your skills were here in Tampa!
[Modified by Biohazard, 1:20 PM 7/19/2002]
Old Jul 19, 2002 | 11:26 AM
AP's Avatar
AP
Default Re: What MultiChannel Amp? (Biohazard)
I just bought the amps 5 days ago, and have not got around to installing it ... I plan to, if needed, to upgrade the battery and then lastly the alternator ... it all depends on the results ...
To What MultiChannel Amp?
