Sponsored by: Innova
Aux mods
Old Aug 28, 2013 | 09:10 AM
Fizbandantalus's Avatar
Fizbandantalus
Default Aux mods
So, yesterday I attempted to do the aux mod. I got my XM unit out went and bought the Male -> Female Aux cable from radioshack and began with cutting off the female end as instructed and come to find out....there are only two wires ( Red and Black ) but under the instructions it lists that it should have 3, so my question is where do I find the approiate cable?????
Old Aug 28, 2013 | 08:13 PM
markcz's Avatar
markcz
Is it a mono or stereo cable ?
If stereo, is there a metal braided shield wrapped around both red/black wires ?
If yes, that's the common -.
Old Aug 28, 2013 | 10:28 PM
Fizbandantalus
So pretty much I bought the wrong cable and need a mono?
And yes the wires were shielded.
Old Aug 28, 2013 | 10:44 PM
markcz's Avatar
markcz
You need the stereo cable.
The shield is common, experiment with black & red wires to see which is left/right.
Normally with headphone type plugs the tip is LH, center is RH, and base is common, but that won't help you
Old Aug 29, 2013 | 09:18 AM
Fizbandantalus
Ya I tried to flip flop them both but when I was reading the how to I was getting lost on the third wire. Ill try again today and see if I messed up by chance.
Old Sep 4, 2013 | 08:05 PM
Fizbandantalus
So I tried reflipping the wires againa and it works!!! So what am I supposed to do with the brown wire? Right now I get a whine whine when I turn the audio up.
Old Sep 4, 2013 | 08:39 PM
markcz's Avatar
markcz
Huh?
Shield (brown?) is the common wire, red is prob right, black is prob left. Make sure they're connected to the three wires the instructions show. If they're correct, try adjusting output volume on ipod/whatever to see if it helps.
If whine won't stop you'll prob have to find an isolation filter of some type to put in the line.
Old Sep 4, 2013 | 08:42 PM
Fizbandantalus
My aux cable only had two wires not 3 as listed. And what does the brown connect to? Wiring is not my strong suit.
I am looking at the brown wire on the xm unit, does that need to be wired onto something.
Old Sep 4, 2013 | 08:47 PM
markcz's Avatar
markcz
Do you know how to post pics? If yes, please post a clear pic of the cut/stripped end of your cable.
If not, please explain the wire colors again, and if there is/isn't a metal braided shield between the outer insulation and the two inner wires.
Old Sep 4, 2013 | 09:27 PM
Fizbandantalus
AUX - Red - Green/White (Right Audio) --- How I have them connected now
AUX - Black - Brown/White (Left Audio) -----^
On the Aux cable there are two wires, red and black. The cable has a metal braided shield that insulates the two aux wires.
Its thunderstorming outside and am unable to get pics atm.
Old Sep 4, 2013 | 10:13 PM
markcz's Avatar
markcz
No pics needed. Connect the metal braided shield to Tan/White just like it was a third wire, the whine will probably go away and you may gain some volume also.
Old Sep 5, 2013 | 08:09 AM
Fizbandantalus
Sweet thanks, ill give it a try today.
Old Sep 6, 2013 | 09:11 AM
Fizbandantalus
When i cut the tan white some of the whine came out but connecting it to the shielding doesn't seem to help at all, its more obvious now with higher volume.
Old Sep 6, 2013 | 04:37 PM
markcz's Avatar
markcz
You can try to splice in a pair of GLI's to get rid of the whine, or get the appropriate aftermarket adapter.
I'm actually surprised you had any sound at all without the common connected, but don't know why you have whine when it is connected.
To Aux mods
