Sponsored by: Innova
Quick wire routing question
Old Sep 20, 2013 | 12:44 PM
J S Machine's Avatar
J S Machine
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
Default Quick wire routing question
When running power, ground, signal, and RCA wires (sub), which ones need to be paired beside what?
I seem to remember power and ground in one loom, and then signal and rca lines in another seperate loom..
Trying to prevent interference.
Am I remembering the correct way?
Old Sep 20, 2013 | 01:20 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
All you need to do is keep RCA away from the power
Old Sep 20, 2013 | 03:55 PM
Fasthotrod's Avatar
Fasthotrod
Yes, you are remembering the correct way. When current flows through the power wires, it creates a small magnetic field that is proportional to the current. If the RCA cables are not shielded properly, then it can induce noise into the RCA cables that you hear as noise in the system.
Keep the RCA's away from the power wires as Pentavolvo mentioned, and you should be good to go.
To Quick wire routing question
