Sponsored by: Innova
c4 new deck install help?
Old Oct 18, 2013 | 02:50 AM
1995corvettecoupe's Avatar
1995corvettecoupe
1st Gear
Default c4 new deck install help?
Can you install an aftermarket deck and keep the stock bose speakers installed ?
Old Oct 18, 2013 | 09:39 AM
-=Jeff=-'s Avatar
-=Jeff=-
Yes..
I have had success with just using the RCA outputs connected directly tot he wiring going to the Speaker modules
Old Oct 19, 2013 | 05:34 AM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
Metra sells a wiring harness adapter for just that makes install easy. I used it with a sony head unit on my 1990. You may have to add resisters if you get the SYS.
http://www.crutchfield.com/p_1207018...n-Adapter.html
Old Oct 19, 2013 | 11:18 PM
JayEmEss's Avatar
JayEmEss
Originally Posted by eutu1984
Metra sells a wiring harness adapter for just that makes install easy. I used it with a sony head unit on my 1990. You may have to add resisters if you get the SYS. http://www.crutchfield.com/p_1207018...n-Adapter.html
So, in my '89 I could repair my stock speakers and then change the head unit...would I need an inline amp? I guess not because the speaker amps would take care of this. And the radio antenna would work? I read somewhere about modifying the wire harness to permit the antenna to work with an after market head unit.
Old Oct 21, 2013 | 07:19 AM
eutu1984's Avatar
eutu1984
With the metra harness the signal to the speakers come from the RCA jacks witch are not amplified, the harness has the wires for the power antenna. I dont now if they make an adapter for your 89 since they are difrent. I got my radio and adapters from cruchfeild, they were very helpfull. as far as i now the power to the amps come from the same relay that powers the antenna, so when you turn on your radio the amps are turned on and the antenna raised at the same time.
Old Nov 18, 2013 | 05:11 PM
07STSTTBASE's Avatar
07STSTTBASE
Default did you have to remove anything?
when you use this harness can you leave everything in place and just plug in the harness?
Old Nov 18, 2013 | 05:38 PM
eutu1984's Avatar
eutu1984
Except for the radio head unit you can just plug everything in except the wires coming from your new head unit, those have to be connected using crimps or soldering.
http://www.crutchfield.com/g_751/Fac...s.html?tp=3486
Old Dec 19, 2013 | 11:13 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Did you read the C4 sticky at the top of the section?
To c4 new deck install help?
