Sponsored by: Innova
C5 aftermarket speaker problem
Old Mar 3, 2014 | 02:27 PM
Bholifield4901's Avatar
Bholifield4901
Default C5 aftermarket speaker problem
I recently replaced my front Bose speakers with JL Audio speakers. I am having trouble finding out which wires to connect them to. I purchased the Metra connectors but those are a 2 pin connectors and I think the only connector there is an 8 pin from the old Bose speaker. Is there an adapter that I need to buy or am I just tapped into the wrong wires. The speakers work but I hear the whinning noise when driving.
Old Mar 3, 2014 | 10:01 PM
markcz's Avatar
markcz
What model number are the new speakers? Are you replacing just the 3.5' or did you pull the sub out also?
IIRC the 3.5's don't need an adapter, the wires should pull off of the oem spades and slide right on to the new ones.
Old Mar 3, 2014 | 10:07 PM
Bholifield4901
They are JL Audio C2-650x speakers. They have been mounted with the wooden adapter plates to replace the front speakers.
Old Mar 4, 2014 | 10:47 AM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
you can only swap the 3.5 on stock wiring
not replace the sub...
To C5 aftermarket speaker problem
