Is there a difference between the stock radio head unit from a c6 with the bose system and one without the bose system?
I'm trying to find a 08+ head unit to replace the one in my 05 for the aux input and I can't get a definitive answer on whether or not the head units are all the same.
They're not exactly the same, but a newer radio SHOULD work in an '05 for all of the functions that you have now. Of course, any of the features that require plugs/wires that you don't have won't work (XM, BT....).
You'll also need to take it to a dealer after installed so they can match the car VIN to the new radio. Before you start the engine, make sure the radio works when in accessory mode since it will go into lockdown after the car is started.
Have you considered an aftermarket radio? Non-Nav units can do a lot more than just add an aux input for about the same $
Hmm so would the head unit from an 08+ non bose system work on a 05 with bose? And I've thought about aftermarket, but I can't see what I'd need besides an aux in
