Quick Build, 2005 Z51.
I just bought this car about 2 weeks ago. 2005 6 speed Z51, 81k miles. I already replaced the Radio, and added a backup camera on the 3rd day when I got home (20 hour drive). I also just swapped out the transmission fluid last week, felt pretty notchy, and was blocking me out of first gear a little bit. Seems fixed now, or at least a million times better. Did Royal purple fluid. Also bought one of those 3 inch wind deflectors (kinda helps) lol. I also just got a new set of headlight lenses for it. Ill probably do that once the stereo system is wrapped up.
I do plan on doing a "nice" build in this car, but for now, I need to be able to hear my music with the top off. So ill call this my Quick Build, until winter. Then I go all out and do a set of high end front components, ill probably do the Hertz HKS 165XLs, I have them in my 2011 SHO taurus, and love them, then fiberglass box and amp rack and so on.
I do car audio for a living, so most of this stuff I already owned, but overall, it should work nicely for now.
Radio:
Pioneer 6.1 DVD with blutooth and HD radio.
GMOS-04 Harness
Metra Dash kit
Metra antenna adapter
Metra Back up Camera
Fronts:
Kicker QS Components
Alpine 4 channel amp, MRP-F300, bridged to do 150rms X 2
Alpine Mono Sub amp, MRP-M1000
Sub:
Alpine 12inch Type S (way overkill, but Its the best matching sub I have for the amp)
Heres the car, When I bought it, it was plasti dipped BRIGHT orange, and while I did get a ton of thumbs up during the long drive home, it just wasnt for me. So ive been working on getting the orange out of all the little nooks and crannies. Dip Dissolver and a power washer did amazing job of getting it out of all the cracks. Hopefully I think Im done. lol
This is where I started the mock up of the amp rack, and trying to figure out how Im going to fit everything.
Little bit of carpet on the amp rack, clean up the edges and I think its good to go.
Today I made the amp rack, and getting all my wiring lined out, seeing what I already have, and what I need to buy. And just getting everything lined up. I also did buy a set of 10inch to 6.5 adapter plates that I found online for the front doors. I figured for $15 id try them out. I wish they were thicker, they do seem pretty solid, but i might use them as a template and make a 2nd layer out of ABS so I can double them up, or just wait and see how they feel after mounted to the door, the speaker, and wrapped in dynamat first. lol
Well, thats it for this post, just thought id say Hi, and show my current Quick project.
I did get the amp rack carpeted, and the plan is to pull the car apart and do this install over Sunday and Monday.
Heres just some of the stuff I have laying around I was debating on installing. lol
Top to bottom, Alpine Type Rs, Polks, Kicker QS, and then 8 inch Daytons. I have a 2nd stash at work. lol
And yes, the targa top still fits in the trunk.
Back up camera automatically turns on in reverse, but I can also turn it on any time I want as well. Not sure why id want to, but hey, I can. lol
Mounts behind plate, and pokes over the top.
Pioneer while playing the radio. You can change all the graphics, and colors, im still undecided. I did white and red to match the gauges, white is easier to read so I made the buttons white, with a red screen.
And the Mic mounted above the rearview, I doubt it will work with the top off if on the highway. lol
