Upgrade Nav/Stereo system install testing question
I have a 2008 C6 base A6
No Bose, standard factory system and speakers
OnStar installed but no subscription, wish to retain capability
A Metra VT-GMOS - 04 integration adapter
A Metra E-5000 relay included
A rear view camera is being added
A Kenwood KCA-IP302 interface cable for ipod/iphone
Any comments or suggestions would be welcome.
no
you do not need to put it back in
A Metra VT-GMOS - 04 integration adapteryou will want to use th c2rgm24 harness and not the gmos if you ask me
A Metra E-5000 relay includednot needed
A Kenwood KCA-IP302 interface cable for ipod/iphonewrong ipod cable you need the ip202
Thanks for the response, I need as much help as I can get. I ordered the KCA-IP302 cable for another head unit but changed to the DNX890HD thinking the iPod KCA cable would be the same. My mistake, thanks for catching that. I am looking into the alternate interface and the need for the relay after your comments.
If you want to retain OnStar functionality you can't use the C2R-GM24. The GMOS would work, but I believe the OS-2C would be a better choice. Dennis can prob confirm this.
Not on your list of parts that you'll also need are an antenna adapter and mounting adapter plate.
I have run into the intermittent "stuck in park syndrome" on C5's and C'6's automatics and so while I had everything apart I attacked the old Kenwood DNX5160 stereo/nav with the intention of updating it to HD radio. In the end I decided to upgrade to a new system that will be compatible with an iphone 4S. Current state is I have the old system and interface cable out and I am waiting for delivery, scheduled Monday (7/7/14), of the DNA 890HD, Metra gmos4 cable and relay plus the mounting plate from C*****field. I do have the GM antenna adaptor, thanks for catching that. I will order the KCA ip202 tonight or tomorrow.
I forgot to mention I also have a HUD installed. It doesn't have all the bells and whistles that comes with the factory nav installed system but has the basic speed etc.
I just found out that the 890HD can access the OBD system and will look for the appropriate interface cable.
I also have the Sirius radio module and antenna from the existing system that I would like to transfer to the new system if possible although I do not have a subscription, looks like a simple plug in.
Thanks for your response, looking forward to hearing from you.
I do have an OBDII to wifi device made by PLX, the KIWI. You can connect it to the OBDII socket and an iPad/Iphone through the wifi system. You then have to purchase 3rd party software to view the data. Quite a nice system with good graphics but not usable while driving except by a passenger.
I recently ran into a problem when I filled up with gas and the gauge only read about 50% full. I got cryptic warnings on the DIC about a fuel system failure and my available range (miles) did not update from before the fill up. When I got home I plugged in the OBDII device and it said left fuel sensor failure. Fortunately it was covered by the extended warranty, but with only 4 days remaining! It saved days of troubleshooting that would have likely extended past the warranty expiration date.
Possible need for OBDII information:
Since I now have about 105,000 miles on the car (2008) and plan on continuing extended road trips I may start to see these types of failures and I thought an "on line" OBDII report would be useful. The 2014 DNX891 model does have wifi capability but I think you would still need some type of software to view the data even if you could connect with the PLX wifi transmitter. For now I will live with the PLX device and an iPhone/Ipad.
also
the DNN991 is the wifi unit....not the DNX891
