Sponsored by: DashLynx
*Group Buy* VetteNuts C6 Insulation Kit and Premium Kit Sale Starting at $145 Shipped
Old 07-12-2014, 11:42 AM
Marc@Vettenuts.net
Supporting Vendor
Marc@Vettenuts.net's Avatar
St. Jude Donor '11
Default *Group Buy* VetteNuts C6 Insulation Kit and Premium Kit Sale Starting at $145 Shipped
After many request from members we are going to do a GROUP BUY on the Insulation kits on for the first 20.
Please choose from coupe, Vert or Z06/FRC when ordering, also manual or AT.
615-896-6100
VetteNuts has sold 1000's of these kits here on the forum. We build these in house and is the # 1 selling kit. There is a lot of customer feedback about these kits installed here on the forum.
Retail $199 plus shipping
$145 shipped in the continental USA.
**Upgrade to our # 1 Selling Premium Kit when checking out for a $60 savings!**
ORDER HERE
Don't forget to order a roll of tape!!
C6 Pre-Cut Full Insulation Kit
The C6 Pre-cut Insulation kit comes with everything you need to insulate and provide sound deadening in your Corvette, including Pre-cut pieces for your doors.
Other kits on the market provide a similar product, but do not provide pre-cut pieces for your doors and storage bins, which allow road noise to be present in your front and rear cabin. Our kit gives you everything you need to COMPLETELY insulate your C6 Corvette.
Our kit is a non-fiberglass, non-asphalt based product which weighs in at 3.5 lbs, for those who are weight conscious, it rejects 97% of the radiant heat, and has a manufacturer's rating of 19db of sound and road noise reduction!!! (please see the notes below on this... )
It is only 3/16" thick, so as not to interfere with proper mounting of your panels and seats, and all holes are pre-cut & all pieces are clearly labeled for your convenience.
It is our #1 goal to provide you ease of install, while making a HUGE improvement in your overall enjoyment of your Corvette!!!
Each kit is hand cut to our specifications, and guaranteed to make a dramatic difference in your C6!
Each kit comes with the following pieces:
  • Driver & Passenger front floorboard pieces, with holes cut for seat bolts and pedals.
  • Driver & Passenger side tunnel pieces, cut around your e-brake.
  • Full center console pieces, with holes for the center console bolts.
  • Driver & Passenger side Door Panel pieces.
  • Full Cargo area floor pieces.
  • Full Side rear wheel well pieces.
  • Full back wall and corner pieces.
  • Full Center Well pre-cut pieces.
  • Extra pieces for odds and ends coverage that you may need.
Say goodbye to over-heated center consoles, and noisy front cabins!! Our C6 kit is the perfect addition to your C6, and is recommended for every Corvette owner as the #1 modification for their Corvette!!!
Your Corvette will be cooler in the summer, a lot less noisy, and you will regain use of your center console once again.
A lot of research and development has gone into this kit, and we are proud to say that our kit is made to our demanding specs, in house, and cut off of our own templates.
Some have emailed and asked, so here is a picture of the material, as well as some specs on the material itself:
It has 5 layers, and though it is rated at a 19db drop in noise, my customers have tested it in the Vettes at 8-11 db. reduction. Here are some manufacturer specs on it:
Characteristics | Value | Regulation
Cell Structure: Closed
Nominal Thickness: 5 mm (+ or - 0.5mm)
Steam Permeability: 0.033 gr/m2hkPa ASTM E-96
Noise Insulation: 19dBA IRAM 4063 at 50hz.
Flame Spread Index/Class: 25 or less/ "A" - Class 1 0 ASTM E-84
Smoke Index/Class: 450 or less/ "A" - Class 1 15 ASTM E-84
INSULATION LAYERS
Aluminum Foil
polyethylene backing
closed-cell Polyethylene foam
Aluminum Foil
**Premium Layer**
Our Best Seller!
Here is another great Insulation package from VetteNuts. It is a peel and stick Ensolite IUO insulation material. This was designed by NASA for the space program.This is a very high grade foam/adhesive combination that will handle high heat, is fire retardant just like regular IUO and is stretchable enough for easy install. It resembles a wet suit material.This kit will make a huge difference in heat and road noise while adding only 3lbs to your Vette. This kit includes every section above, the Ensolite is applied on top of our Standard kit making it one kit. All sections are clearly marked for ease of installation.
We do not include the kick panel sections. This makes the area to thick to reinstall the plastic kick panels when using both kits.
ORDER HERE
Old 07-18-2014, 10:15 AM
matt_lowry123
matt_lowry123's Avatar
St. Jude Donor '11
Default Thanks!!
Thanks Marc for taking the time to tell me about the kit (super nice guy). I just purchased the premium kit. I'll see you soon for the stereo install.
Old 07-21-2014, 08:37 PM
Marc@Vettenuts.net
Supporting Vendor
St. Jude Donor '11
Sounds great. We look forward to working with you.
Old 07-24-2014, 09:42 AM
Marc@Vettenuts.net
Supporting Vendor
St. Jude Donor '11
Get your kit at the sale price while it last!
Old 07-31-2014, 05:46 PM
crAzy
crAzy's Avatar
How much for just the IOU? I already purchased your installation kit back in Jan of 2013. I feel as if I could use some more insulation to get rid of road noise. Basic kit isn't enough in my Z06.
Old 08-01-2014, 09:31 AM
Marc@Vettenuts.net
Supporting Vendor
St. Jude Donor '11
We can ship you the Premium layer for $200. It will make a huge difference adding it to the top of what you have.
Old 09-06-2014, 11:29 AM
Marc@Vettenuts.net
Supporting Vendor
St. Jude Donor '11
ttt
Old 09-18-2014, 10:07 AM
Marc@Vettenuts.net
Supporting Vendor
St. Jude Donor '11
Get yours today!
Old 10-07-2014, 08:58 AM
Marc@Vettenuts.net
Supporting Vendor
St. Jude Donor '11
Only a few left!
Here is a C5 we just finished for a customer.
Old 10-13-2014, 03:54 PM
Marc@Vettenuts.net
Supporting Vendor
St. Jude Donor '11
Up and away!
Old 10-27-2014, 09:05 AM
Marc@Vettenuts.net
Supporting Vendor
St. Jude Donor '11
ttt
Old 10-29-2014, 01:07 PM
glide
glide's Avatar
St. Jude Donor '13,'19
Originally Posted by Marc@Vettenuts.net
ttt
As a new C6 owner I think the car is pretty quiet compared with my C2 and C5 but if installation is DIY I guess this should be my first mod. Car is 2LT so I'm looking for Kenwood navigation with Bluetooth, XM radio and steering wheel control integration module also. Any and all help would be welcome.
Old 10-29-2014, 06:11 PM
Marc@Vettenuts.net
Supporting Vendor
St. Jude Donor '11
We can take care of all your audio needs along with the insulation kit. We have our corner sub boxes on sale thru the end of the month for $229. They are a great addition to your sound system. Give me a call tomorrow and lets go over your options.
Marc
615-896-6100
To *Group Buy* VetteNuts C6 Insulation Kit and Premium Kit Sale Starting at $145 Shipped
Quick Reply: *Group Buy* VetteNuts C6 Insulation Kit and Premium Kit Sale Starting at $145 Shipped
