Sponsored by: Innova
C6 Door Speakers
Old Aug 12, 2014 | 03:17 PM
jimy's Avatar
jimy
Default C6 Door Speakers
How many people are putting the crossover for the 6.5" components in the door? I understand that water is a big concern doing that but is there any other problems? Anybody have any pictures of their crossover in the door and where they installed them?
Old Aug 12, 2014 | 10:10 PM
markcz's Avatar
markcz
Putting them in the door really isn't an issue, but I would avoid hitting the lower window seal with a pressure washer.
In C6 there's room in the foam insert for most crossovers, or just double-sticky tape it to the floor.
Another option is outside the door, up under the dash next to the accordian gizmo opening. Lots of room up there and doesn't really use much more speaker wire.
Old Aug 31, 2014 | 01:43 PM
[Cerberus]'s Avatar
[Cerberus]
When I had my system put in, he put the crossovers where the factory AMP was placed under the passenger footwell using some PVC board to prevent moisture swelling.
These are his photos using a cell phone, I tried to edit them up a bit but only so much you can do.
To C6 Door Speakers
