Digital Time Correction? Subwoofer Phase Control?
It also has Subwoofer Phase Control ... what is that? how does it work?
Normally this kind of thing is used in large stadiums and even home theaters where you have multiple sources and significant arrival time differences.
The only use that would make sense in a car would be to align a tweeter 6" from your ear and a woofer in the trunk.
The sub phase control--well think about a pure, clean bass note. It is basically a sinusoidal + and - pressure variation above and below ambient air pressure. At each point in the cycle there is an amplitude of wave and an associated phase, relative to the initial zero point. One complete + and - cycle sweeps through 360 electrical degrees (like a complete circle is 360 mechanical degrees.)
The idea is to get the sub output "in phase" with the woofers at the overlapping frequencies so the acoustic output adds for strong bass. Since the manufacturer doesnt know the relative polarities of the various woofers and subs being connected (determined by how a particular driver is charged (magnetized) and connected, usually when a positive voltage is applied to a + terminal, the woofer cone will move "out" towards you, you can check with a 9V battery.) or the location of the sub relative to the woofers, they need a way to make sure you can make the output of the sub and the woofers add in such a way as to reinforce each other--if they dont add in phase you will notch the bass output in the overlap region.
If you add additional reactive network components (caps, inductors, etc.)they add phase shift and it might turn out that you need to intentionally invert the sub electrical phase relative tp the woofer so they will sum acouistically.
You can also use the phase control to reduce huge peaks in the sub-woofer overlap area by intentionally ofsetting the relative phase of the sub output wave relative to the woofer.
This does not even touch on bass response and modal behavior in a small pressure box (a car interior), etc.
Thanks ... do you have any idea how this would be setup in a car with 4 speakers and 2 seats, I understand how to do it for 1 person in the car, but for 2 i am stuck?
It's just a trial and error deal unless you have access to an acoustic measurement system, and ultimately if it sounds good to you then you're dialed!
http://teamgates.net/bronco.html
A link to the article
http://www.wired.com/wired/archive/8...reocar_pr.html
I would imagine that most people on here have heard about this truck but it is something when you look at the alternator arrangement. This stereo puts out roughly at 175db. They have a computer if I am not mistaken that does the staging and synchronizing. The sub hits and it draws something like 10k amps for a second to a second and a half. They targeted a spot in the vehicle where a judge would put the microphone in an SPL competition. This is quite outrageous I must say.
Just my opinion though. Thanks,
[Modified by MY2K2C5, 10:37 AM 8/1/2002]
There are two basic ways to set it up. If you want it to be optimal for everyone, then find a spot on the center of your dahs and dela the drives for that. If you want it optimal for the driver, which is what i do, then you measure the differences to all the speakers from the drivers head. This will create an unreal soundstage.
Proper time alignment really works best when all the drivers have been x'dover active, or very close together if passive.
hope that helps.
Scott
hope that helps.
Scott
The above example would require a active xover with a channels of amplication for each driver in order to sound correctly.
btw, have you tried alpine's ipersonalize? it does all the work and lets you create a cdr that will autoload all the settings into your headunit. It can be found on their website.
Make sense? replay again if it doesn't. I don't do the best job explaining at times.
Scott
Scott
Scott
This years top of the line Alpine units have it built in ....!!! thats one of the good things about them :yesnod:
Scott
As far as the time correction is concerned ... I get your point ... if the speakers have a distance between them the timing will be off... but they are very close ... so I should be okay ...
Last couple of years I have been to sick to really go out and do things so I worked on setting up a nice home theatre setup. Now that I feel better thanks to the marvels of modern science, I am getting into car audio.
Exactly! btw, I didn't realize only the 7998 did the ipersonalize. hmmm.....
MY2K2C5:
same concept applies to ht. It comes in VERY handy if ht is not setup symmetrical in the room. I've used this feature on several peoples ht who didn't even realize they had it. :) It made amazing differences.
Scott
Scott
