Sponsored by: Innova
Retrofitting 2006+ Antenna into 2005 C6
Old Dec 28, 2014 | 08:09 PM
LJD51's Avatar
LJD51
From: North Strand, NMB, SC; Retired x 2 (US Army: 70-90 AD) (US Army: 91-16 DAC); yea, I'm old.
Default Retrofitting 2006+ Antenna into 2005 C6
As the title says, I am looking into the possibility of retrofitting my '05 coupe with the antenna system from an '06+.
Background: Car came with factory nav which was replaced with a Pioneer AVIC-X920BT. Everything worked fine but recently had the opportunity to install a Kenwood DNX891HD with a backup camera. I had both units installed at the same shop where I have had work done in the past with no issues.
Since swapping the units, the AM/FM reception has been less than optimal; there is a lot of static and inability to lock onto stations the Pioneer had no issues with receiving.
I am going to take the car back and have it checked, but if the problem persists, what is needed to "upgrade" to a '06+ antenna setup.
Any help is greatly appreciated.
TIA.
Old Dec 29, 2014 | 09:51 AM
markcz's Avatar
markcz
I thought the '05 antenna was the same as 06+, but I could be wrong about that.
Sometimes changing the ground location of the radio will help reception.
If you're going to change any antennas out, I'd go with THIS ONE before another stock version
Old Dec 29, 2014 | 03:23 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I have 05, and have the same Kenwood, and needed adapter for the antenna, no problems with receptions.
Old Dec 30, 2014 | 07:52 PM
LJD51's Avatar
LJD51
Thanks.
Do you remember the make/model of the adapter used in your setup?
Old Dec 31, 2014 | 08:18 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
Originally Posted by LJD51
Thanks.
Sorry, had it professional done, looking at bill they used radio to gm ant w/mni 40-gm10 $15.00.
I think if you call place that installs radio, they would know, and more then likely have them in stock.
Hope this helps.
Old Dec 31, 2014 | 10:58 AM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
your installer did not install it correctly.
Your problem is...
they did not connect the blue antenna wire.
Most think that since you do not have a power antenna that they do not need to connect this. However for best AM FM reception and for HD radio reception this has to be connected...
Old Dec 31, 2014 | 11:01 AM
0Double D Mods
Former Vendor
Hope this helps.
15.00!!!
Wow
We sell this for 4.99
Old Dec 31, 2014 | 11:19 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
Originally Posted by Double D Mods
15.00!!!
Wow
Thanks Dennis, I new they they were high, but I didn't do my homework like I usually do when buying anything, I guess I what they call a senior moment.
Have Happy New Year Dennis.
Old Jan 1, 2015 | 07:45 PM
LJD51's Avatar
LJD51
Thanks Dennis... since I have tomorrow off, I will be contacting my installer to set up an appointment to have him pull the unit and check all the connections.
Happy New Years to one and all...
To Retrofitting 2006+ Antenna into 2005 C6
