Sponsored by: Innova
Pioneer 4199NEX
Old Apr 24, 2015 | 11:38 PM
1badazc6's Avatar
1badazc6
Default no audio
Originally Posted by markcz
Are the RP4 RCA's connected to the proper HU preout locations?
On some HU you can turn speaker or preout outputs on/off in settings. If yours has that make sure the preout outputs are on.
Can you see indication of volume changing on the HU or does it indicate mute?
Mark..i will check to see if the 992 has pre-out on & off. Just got in from a 24+ hour shift. I will check the C1 B3 factory bose amp turn on. It looks as if out of the RP4 there a solid blu wire is going to C1 B3
