So I'm using an amp that worked just fine last time I used it.
When I was installing it, like a dumb dumb hook the power up to the battery then hooked the amp side power in after. it sparked and blew both fuses.. I then got new fuses and plugged the amp up then to the battery. But nothing is turning on. The fuses aren't blown.
Connect a jumper from red power wire on amp to the trigger terminal, you should get something if it isn't dead.
So I ran the amp wire to my other cars battery and still nothing. I rechecked my ground and I grounded it to my convertible bracket(metal) "underneath the seat belt plastic piece".
My fuses are good. Like I said the original ones blew when I plugged it in.
