Sponsored by: Innova
Backup Camera Question
Old Sep 4, 2015 | 01:36 PM
COCO RICK's Avatar
COCO RICK
Default Backup Camera Question
I just purchased a mirror mounted backup camera system for my base 2007. I previously installed one in my avalanche. After reading a couple of hours worth of threads here, I have this question;
I connected the camera to the reverse light (so it only comes on when in reverse)and the monitor to the auxiliary outlet. With the ignition off the monitor is still powered but the camera isn't, so I figured there would be no battery drain.
Is this wrong?
Old Sep 5, 2015 | 12:29 AM
markcz's Avatar
markcz
Is this wrong?
It depends on how the monitor was made. If it was designed to only turn on when there's a camera input present, then you're fine.
If it's like most devices and stays on as long as it's powered, then you're in for some battery trouble.
You can tap the reverse power in the footwell in C6, check out post #2 HERE
Old Sep 5, 2015 | 11:13 AM
COCO RICK's Avatar
COCO RICK
Thanks for that reply Mark.
Because my monitor has two inputs, I've had decided to add a second camera in the front. I found this write up "Front & rear backup / parking cameras , installation" from Chevy Dave, which requires a push button switch to shut all power to the system off when not in use.
That switch made me change my mind again and just go with the backup camera.
So your reply showing the reverse wire is exactly what I need.
Thanks again, Rick
To Backup Camera Question
