Sponsored by: Innova
wiring question
Old Apr 29, 2016 | 10:18 PM
Dave concrete's Avatar
Dave concrete
Default wiring question
Anyone here not use the crossover in their components and wire two tweeters, two 6.5's with a 4 channel.?
I have a Arc 300.4 at 90wx 4 @4ohm and only have doors with speakers.
Old Apr 30, 2016 | 12:15 AM
markcz's Avatar
markcz
Using the crossover on the outlet of the amp is called 'passive'. Putting each speaker on it's own amp channel like you're asking about is 'active'.
It works great, sounds better, and is usually louder, but you have to set it up right or you can damage your speakers or amp.
The gain adjustment for the tweeter will be about half volume of the bass speaker.
Send a full signal into the amp (or HP at ~100hz if you have a separate sub), and set both amp crossovers at 2500-3000ish. HP for tweeter and LP for bass speaker. Arc amps have great internal crossovers
Old Apr 30, 2016 | 05:23 PM
Dave concrete
Thanks. Then how about can you just use the two channels 1 and 2 and not touch 3 and 4 at all so another words it will be 90x 2?
Old Apr 30, 2016 | 05:25 PM
Dave concrete
Thanks. so on a 4 channel, would for instance channel 1 be the 6.5 and channel 2 be the tweeter same door?
Old May 2, 2016 | 12:28 PM
markcz's Avatar
markcz
Put one set (6.5) on Ch 1&2, and the other (tweets) on 3&4. It doesn't matter on your amp which is where (both internal crossovers are fully adjustable), so you could put tweets on 1&2 if you want.
To wiring question
