Sponsored by: Innova
Ok guys...I need some help. Cap. Install ? ?
Old Sep 16, 2002 | 08:06 AM
C5MongooseTX's Avatar
C5MongooseTX
Default Ok guys...I need some help. Cap. Install ? ?
How exactly do you install a stereo Cap. ? . . .Do you just put it in between the battery and distribution block power wire...and then ground it ? Or is there a trick to it ?
Derek :cool:
Old Sep 16, 2002 | 02:31 PM
Conquer's Avatar
Conquer
St. Jude Contributor
Default Re: Ok guys...I need some help. Cap. Install ? ? (C5MongooseFL)
NEEDS TO BE INSTALLED AS CLOSE TO THE AMP AS POSSIBLE. DO NOT PUT IT BETWEEN THE BLOCK AND THE BATTERY....PUT IT BETWEEN THE BLOCK AND AMP (THE CAP DOES NOT NEED TO BE FUSED). AGAIN *IMPORTANT* AS CLOSE TO THE AMP AS POSSIBLE! THIS WILL ALLOW FOR BETTER PERFORMANCE. I'D GIVE IT A RULE OF LESS THEN ONE FOOT IF POSSIBLE.
MY $0.02 :)
AND YES! "GROUND IT"! (CLOSE AS POSSIBLE) :yesnod:
[Modified by Conquer, 6:35 PM 9/16/2002]
Old Sep 16, 2002 | 02:41 PM
Conquer's Avatar
Conquer
Default Re: Ok guys...I need some help. Cap. Install ? ? (Conquer)
THIS LINK MIGHT ALSO BE OF SOME HELP:
http://www.caraudioanswers.com/article.php?sid=122
Old Sep 16, 2002 | 09:21 PM
ZippoMan's Avatar
ZippoMan
Remember that the cap should be charged before installation (they usually come with some kind of 'charge card' or instructions on how to charge it) and do not touch the caps positive and negative leads together as this will discharge it.
[Modified by ZippoMan, 5:21 PM 9/16/2002]
Old Sep 17, 2002 | 01:40 AM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Default Re: Ok guys...I need some help. Cap. Install ? ? (ZippoMan)
I got this question answered long time back ... but still got one more question.
My CAP can only got charged up to 10 Volts (I don't have a charged card so I use a 10K, 1/2 Amp resistor ... yep, could not find 1 Amp or maybe I got a bad CAP) so when I hooked it up to the battery, there was not spark or what so ever.
Right now, there's always a constant 12V to the CAP. So will the CAP got charged up to 12V or it just stays at 10 Volts?
Old Sep 17, 2002 | 04:25 AM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
Default Re: Ok guys...I need some help. Cap. Install ? ? (mike76002)
Yes, it will charge to 12v.
To Ok guys...I need some help. Cap. Install ? ?
