Sponsored by: Innova
Which PAC Unit
Old Aug 22, 2017 | 05:51 PM
carls2004's Avatar
carls2004
Default Which PAC Unit
Little confusing on which PAC UNIT to get for my 2006 vert with Bose and Onstar.
Been chasing a issue, So im willing to buy another..
The one that is in my car now i think is
Pac OS-2C Bose Onstar Interface For Class Ii Vehicles Equipped With Factory Bose
But im just going by the look's of this one to whats in my car now..... Cheapest is best because of funds...
More info,, I wouldnt need onstar, or even the bose amp either as im running my own amp..
Old Aug 22, 2017 | 07:14 PM
TorchRedFred's Avatar
TorchRedFred
Pac Audio RP5-GM11 will work with or with out Bose and OnStar, also gives you door chimes and steering wheel controls. It's not cheap though, about $98 on Amazon.
Never mind, just saw your edited post where you no longer need Bose or OnStar compatibility, you can still use it but it may not be the cheapest option.
Old Aug 22, 2017 | 07:55 PM
carls2004's Avatar
carls2004
I sent a P.M. to DD, to see what he has and price.. May be my best option
Old Aug 24, 2017 | 11:27 AM
Homer3D's Avatar
Homer3D
First ask yourself if you still need the use of OnStar. If you do then you should RP5-GM11. While my GS has Onstar I don't use it so I picked up the RP4-GM11 which gives me to 2 functions per button. Press + Press/Hold. For example, I hit the phone pick up button and it will answer an incoming call. If I hold down the phone pick up button it will activate Siri.
Old Sep 3, 2017 | 07:45 PM
Pump77's Avatar
Pump77
Default Pac os-2x
PAC OS-2X allows retaining OnStar , Bose or no Bose.
PM sent
To Which PAC Unit
