Sponsored by: Innova
10 in sub/amp combo recommendation
Old Jan 21, 2018 | 08:23 PM
STL Mike's Avatar
STL Mike
Default 10 in sub/amp combo recommendation
Looking at adding a sub when I upgrade to a double din on my C5Z. Factory speakers will stay.
Don't need anything crazy, actually been looking on marketplace/Craigslist.
Can anyone make a recommendation of a proven sub/amp combo? Been looking at subthump.com for a box.
Thx,
Mike
Old Jan 23, 2018 | 12:25 PM
Cryptoboy's Avatar
Cryptoboy
From what I've been reading, you'll need something to adapt the new head unit to the stock Bose speakers.
I just put a double din in, Kenwood receiver, JL component speakers in the door, JL Coax in the rear, and a kenwood 5 channel amp. I bought the subthump stealth box and plan to get it installed this weekend when I get home. I'm going with a JL speaker (forget the exact model off the top of my head).
Are you doing the work yourself?
Old Jan 23, 2018 | 12:36 PM
STL Mike's Avatar
STL Mike
Yes, I'm doing the work.
I bought the head unit from crutchfield and bought their adaptor. It should be basically plug and play using their harness between the factory Bose speakers and new double din.
I'm looking at the All In One JBL Bass Pro now. Seems an easier and cleaner install with proven results. I don't need lots of bass.
Thoughts?
Old Jan 23, 2018 | 12:41 PM
Cryptoboy's Avatar
Cryptoboy
Thoughts?
I just didn't like the price. I found one on ebay for $399, said it was unused, but figured the subthump gives better flexibility to pick the sub you want. Just need to make sure you get a sub that is made for a sealed box if you go that route.
Old Jan 23, 2018 | 12:57 PM
STL Mike's Avatar
STL Mike
https://www.jbl.com/award-winners/BASSPRO+SL.html
Old Jan 23, 2018 | 01:42 PM
Cryptoboy's Avatar
Cryptoboy
Ah, I was thinking the JL audio box - it's a custom fit into the recessed area in the trunk, and lists around $750.
Old Jan 23, 2018 | 01:54 PM
STL Mike's Avatar
STL Mike
No, 249 + wiring and done.
Old Jan 23, 2018 | 02:20 PM
Cryptoboy's Avatar
Cryptoboy
Are you planning to put it under the passenger seat? Let me know how it works out!
Old Jan 23, 2018 | 04:44 PM
STL Mike's Avatar
STL Mike
I built a compartment divider with sound deadener. The cockpit is now much more quiet. I intend to put it in the back and secure it. I'll be sure to keep you up to speed!
Waiting on my double din console from vette nuts right now.
To 10 in sub/amp combo recommendation
