Sponsored by: Innova
AM radio problem
Old Oct 12, 2002 | 12:46 PM
rons99's Avatar
rons99
Active Streak: 90 Days
Default AM radio problem
Hi All -
I'm the proud new owner of a '99 - my first Corvette. Wow!
Problem - The am radio won't work when the ambient temperature is hot. Sounds like the antenna is disconnected. Mostly static. Not engine noise - not rpm related. Just sounds like no antenna.
Any ideas how to fix?
Old Oct 12, 2002 | 06:57 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: AM radio problem (rons99)
If you have fm reception then its not the antenna. They use the same one. If you were getting the AM in other cars at the same locations you aren't getting it in the vette you may need a new receiver.
