IASCA SQC competition novice class build
The components of the build have been selected and most of it was previously installed. So I am having to re-install the components with the new purpose and goals.
The parts:
Alpine iLX-207 7-INCH AUDIO/VIDEO RECEIVER
Metra DP3021B Bezel
Straightwire wiring
Helix DSP.2 Processor
Mystery Amplifier - can't decide between Arc Audio and Mosconi
AudioFrog GB10 Audiophile Tweeter
Nemez111 German Twitter pods
Stereo Integrity TM65 mkII midrange
Metra 82-3013 Speaker Adapter
JL Audio 10" subwoofers
Subthump Partition subwoofer box
Sound Deadener CLD, CCF, and MLV
Dashmat 7834-1002
SDS CLD only requires 25% coverage to be effective.
You don't have to cover every sq. in. with dynamat.
Let the pictures begin.
Dashmat installed
CLD installed
Audiofrog installed
Butyl rubber rope.
Driver footwell
Passenger Floor
Rear wall
Driver wheel well
Behind seats
Rear compartment
CCF - closed cell foam - foil lined
MLV - mass loaded vinyl.
I went with 40 sq ft. of MLV to start. I added 16 sq ft. more in the back, as you see. I could use another 1' x 6' section under the passenger seat.
But the noise level reduction is very noticeable. The doors are heavy and solid.
Where I do notice noise is from thru the glass in the doors but I can't remedy that. Also through the rear wheel arches, I could try melamine foam back there.
I will RTA the car this weekend.
I have NO DSP. Just the Pioneer AVC8100. All speakers are "HPF on." Fronts are crossed at 63 Hz to 18db slope. Rears are 200 Hz dropped 12 db slope. Sub is "LPF on" 63 Hz sloped at -12 db (so signs off by 100 Hz) Sub is a single JL 10W7 on 500W. Other speakers are on a JL 300/4 channel (both Slash series amps).
https://testgear.audiofrog.com/wp-co...y-it-Works.pdf
Nice.
