Sponsored by: Innova
Adding a front camera question
Old Feb 27, 2018 | 02:10 PM
jrprich's Avatar
jrprich
Default Adding a front camera question
I will be installing a new Pioneer head unit in my 04 C5.
While I am doing this I want to add a front camera as well as a rear camera.
The rear camera is easy as it is activated by the backup lights.
My question is, where should I power the front camera?
I was thinking of using the DRL wiring but that will leave the front camera on whenever the car is running.
Any suggestions would be appreciated
Jim
Old Feb 27, 2018 | 04:39 PM
danzio56's Avatar
danzio56
I ran my power using the accessory fuse slot and a fuse tap under the passenger floorboard then ran that wire under the A-pillar cover and then into the engine compartment. I joined the ground wire with this hot wire from a stud in the engine compartment (same one I'm using for my battery tender connection).
Old Feb 27, 2018 | 04:54 PM
jrprich's Avatar
jrprich
So your front camera is always on when the Vette is running?
Old Feb 27, 2018 | 04:56 PM
madsonp's Avatar
madsonp
About all's you can do is add a switch somewhere to turn it off and on when you want, otherwise, yes it will have power when the car is running.
Old Feb 27, 2018 | 06:57 PM
jrprich's Avatar
jrprich
Understood, I planned to hook it to a source that is on when the car is on.
I don't think I will need a switch as I will have to select the front camera from the Pioneer anyway.
Thanks,
Old Feb 27, 2018 | 06:59 PM
J02ws6transam's Avatar
J02ws6transam
Is it bad to leave it powered while the car is running? I am about to add a front camer to my c6 and wondering the same thing. I know the rear camera will only be powered while it’s in reverse from the back up lights but the front would be powered all the time and I turn the front camera on the screen by pushing a button on the head unit. Is it bad for the camera to always have power when the car is on?
thanks
jon
Old Feb 27, 2018 | 07:26 PM
danzio56's Avatar
danzio56
Yes it's on with the ignition. Nothing wrong with that. It's a camera. If you have a dash cam it's always on. And they're cheap anyways. The one I have cost me $12 on Amazon and is easily replaceable because of the way they're wired. Pull the old and plug in the new. But I would imagine this camera will last a long time, but we'll see.
Old Feb 27, 2018 | 07:28 PM
danzio56's Avatar
danzio56
thanks
jon
This is not true. My rear camera is on with the ignition as well. I can bring up the camera view on my Head Unit anytime I want and switch between front and rear cameras with the push of a virtual button (on the video screen).
Old Feb 27, 2018 | 07:42 PM
Ahrmike's Avatar
Ahrmike
You could run it off the fog wiring and flick the fog light switch when you want the front facing camera on
Old Feb 27, 2018 | 08:17 PM
J02ws6transam
Thanks for the advice guys. I’ll leave it powered all the time when then key is on.
To Adding a front camera question
