Sponsored by: Innova
My C6 Convertible Crossover install/mount
Old May 15, 2018 | 07:51 PM
Callaway DrDon's Avatar
Callaway DrDon
Default My C6 Convertible Crossover install/mount
I went with Focal 165AS component speakers for the doors after reading several reviews and on Crutchfield's recommendation. They sound great.....loud, clear, and crisp. One problem is the fairly large crossovers they come with. I already choose to mount the amp under the waterfall. For the crossovers I mounted them in place of the stock Bose amp in the passenger footwell. The Bose amp was not going to be used and can easily be removed in 5 minutes. 4 screws and unplug the harnesses. I used the removed Bose amp as a template, and sheet of marine plastic from West Marine as a mounting plate. Very easy to cut with a jigsaw. After cutting the template, I mounted the crossovers with 2 through bolts each. Wired up the component speakers, and then reused the 4 screws that held the Bose amp to secure the whole plate. The bottom picture shows a trial fitting. The cross overs come with a three position toggle switch to adjust the high frequency of the tweeters. With this location you can reach in and adjust to your preference, which would not be so easy in a door mount . They are also dry and stable in this location. Wiring was fairly easy. Speaker wires from the amp under the waterfall, run under the center console up behind the radio, and then behind the dash to the crossovers.
Then wires from the speaker components through the doors to the crossovers.
Old May 16, 2018 | 07:17 PM
madsonp's Avatar
madsonp
Looks good !
Old May 25, 2018 | 03:29 PM
Vette_Fan's Avatar
Vette_Fan
I like your custom work.
Since I have a vert too, I am curious to know where you installed your amps and what's your set up for bass?
To My C6 Convertible Crossover install/mount
