Sponsored by: DashLynx
Question on double-din / RP5-GM11 install
Old 05-17-2018, 07:42 AM
lowNslowZ
lowNslowZ's Avatar
Default Question on double-din / RP5-GM11 install
Hoping someone can help me out here on my C6 double-din install. I am using the PAC RP5-GM11 harness to hook up the head unit and along with the instruction guide for the harness there was an extra slip in the package stating that for high power double-din units 2 jumper wires MAY need to be installed. I have linked to these instructions from PAC's website below. I have looked through several install guides here on the forums and I don't see any mention of this on any installs. Is this something I need to do or not? Thanks in advance for anyone with any info.
https://pac-audio.com/index.php?cont...attachment=961
Old 05-18-2018, 11:51 PM
Coupe89
Coupe89's Avatar
St. Jude Donor '05-'06
When I did mine. I did not do that to mine.
Old 05-19-2018, 12:13 AM
madsonp
Support Corvetteforum!
madsonp's Avatar
Received 1,757 Likes on 1,169 Posts
Mine didn't even come with those instructions, so needless to say, I didn't do it either.
Old 05-19-2018, 09:27 AM
lowNslowZ
lowNslowZ's Avatar
Thanks for the responses. Just finished up the install last night and had no issues at all installing the unit without the jumpers installed. I will update the thread if i have to go back in and install them for any reason
Old 05-19-2018, 10:53 AM
madsonp
madsonp's Avatar
What kind of head unit did you install ?
Old 05-19-2018, 11:42 AM
lowNslowZ
lowNslowZ's Avatar
It was a kenwood DDX9704S
Old 05-19-2018, 12:16 PM
madsonp
madsonp's Avatar
Nice, I did the Pioneer AVIC-8200 NEX myself.
Old 05-19-2018, 12:28 PM
lowNslowZ
lowNslowZ's Avatar
Nice, i was actually surprised at how easy the install was. Eveything could be soldered outside the car then its pretty much plug and play. Actually took me longer to run the backup camera than to install the head unit
Old 05-19-2018, 12:31 PM
madsonp
madsonp's Avatar
I agree, it was probably one of the easiest installs I've ever done and I've been doing installs on my own vehicles for 40 years.
Old 05-20-2018, 09:00 PM
c6don
c6don's Avatar
I just added a backup camera also. Where did you put the camera?
Old 05-22-2018, 07:59 PM
lowNslowZ
lowNslowZ's Avatar
I mounted it just next to the passenger side license plate light. I was able to use the same screw to mount the camera that holds the light so there was no drilling/cutting needed
Old 05-25-2018, 03:22 PM
Vette_Fan
Vette_Fan's Avatar
I also bought the 8200. Haven't installed it yet. How do you like it? What are some of your favorite features of this head unit?
Did you change the entire system in your car? Is this harness required if I plan on changing the entire system?
Since my car is a vert, having a hard time trying to figure out the best/space saving options for adding BASS.
I am going with a 4 chnl amp that will power 6.5" component speakers in the doors, upgrade rears to 2-way coaxial 5.25 speakers, but still not decided on the options for bass & adding a 2nd amp. What's your expert opinion on this (vert)? Thanks...
Old 05-25-2018, 03:31 PM
jeffs64
jeffs64's Avatar
Got any pic's of the backup cam ?
To Question on double-din / RP5-GM11 install
Quick Reply: Question on double-din / RP5-GM11 install
