Need help 2013 z06 mem settings vs radio???
So I never have posted here IIRC but here goes. I tried following the supp navigation/stereo etc manual but it's not clear what I'm doing wrong.
I set the radio stations per directions. I don't see any "SAVE" button.
Then when I use memory 1 (or2) for seat exit/seat position, whatever else, the radio stations get all out of sequence.
Did I miss a step or do it in the wrong order or what?
Thanks, noob to audio
Just want my preferred stations to be set & left alone.
If it's in a sticky, sorry, but time is of the essence, don't have hours to read stickies & the forum search function is, well, you know.
Well no help on this sub forum? I think I figured it out anyway.
If I am correct, the radio stations are memorized to fob/driver #1 if that is what is "active" when you go thru the process
or
the radio stations are memorized to fob/driver #2 if that one is "active" when you do it.
I guess that makes sense, wish it had been explained in plain english in the supplement nav/radio booklet.
So if for some other reason (say you like to have two seat positions) and use both mem1 and mem2 buttons, then, you should go thru the process and set your favorite stations under both.
or
or
or
