Rear speaker hum. Temp fix?
I know the correct fix is to just tear things apart and figure out a different way to rout my rear speaker wires. I just don't want to mess with that until next winter, and I do not recall there being that many options and getting the carpet to lay flat and the trim reinstalled. So it's either disconnect the rear speakers and amp, or try to use an isolator of sorts... The rears are just fill anyway, so sound quality isn't terific.
Based on this, what isolator, or other method/gizmo would you guys recommend I try?
