Sponsored by: Innova
Double DIN install, shelf rivets
Old Jun 8, 2018 | 06:12 PM
huesmann's Avatar
huesmann
Default Double DIN install, shelf rivets
What's the easiest way to remove the rivets from the OEM radio shelf, so it can be removed or moved down?
Old Jun 8, 2018 | 11:49 PM
jrprich's Avatar
jrprich
Many different ways.
I doubt there will be agreement as to which is easier.
Two methods seem the most popular
Saw them out. This was my choice, but I also have a nice cordless reciprocating saw and the correct blades on hand.
Drill them out, but you will likely need a 90-degree drill. I tried this first but in my case, I didn't have any short bits so my 90-degree drill was useless for this task.
Old Jun 9, 2018 | 07:56 AM
huesmann's Avatar
huesmann
I do have a 90º drill, but it seemed slow going. I do have a sawzall with Torch blades. Maybe I'll try that. With the saw you basically saw the head off, cutting parallel to the surface of the shelf tab?
Old Jun 9, 2018 | 11:17 AM
jrprich's Avatar
jrprich
I placed my blade between the cage and the shelf and pushed down. Tool a bit but it did work fine
To Double DIN install, shelf rivets
