Sponsored by: DashLynx
New Head unit - do I need to redo all speakers?
Old 08-27-2018, 08:27 PM
CrystalRedTed
CrystalRedTed's Avatar
Originally Posted by Hirohawa
I already have XM in the car do I need any cables or extensions or does the GM PAC 5 harness take care of XM as well?
If you want to keep XM you'll need to install new XM hardware. The stock XM isn't usable with the aftermarket system. Some people have managed to re-use the antenna, but that's it.
Hirohawa (08-28-2018)
Old 08-27-2018, 08:50 PM
TorchRedFred
TorchRedFred's Avatar
Received 1,636 Likes on 1,121 Posts
You need to purchase the XM tuner, and it attaches to the back of your head unit.
Amazon Amazon
You can re-use the factory antenna. I did but I found the reception was still poor. If you want to try it you need to buy the Sirius/XM 10ft antenna extension and run it to the factory XM location above the rear drivers side wheel well.
Amazon Amazon
Old 08-27-2018, 10:41 PM
CrystalRedTed
https://www.amazon.com/gp/product/B00NJTO4CY/ref=oh_aui_search_detailpage?ie=UTF8&psc =1
https://www.amazon.com/gp/product/B00DMFAOA6/ref=oh_aui_search_detailpage?ie=UTF8&psc =1
When I bought my C6 in December I activated an XM trial on the stock Bose system. I found the quality just awful and didn't listen to it after a day or two and went back to streaming from my iPhone. So when I installed my 8201NEX I didn't bother installing the XM hardware. Then I started wondering. How have you found the sound quality of XM with the aftermarket setup?
Old 08-29-2018, 05:03 PM
biggator6
biggator6's Avatar
I finally decided to test XM. My other car (2017 Explorer Platinum) came with the trial.. even in a new car, it is awful. So I finally decided to test listening to a song on XM, then flipping to the app, where you can restart the song from the beginning.
Listening back to back - the app sounded a TON better than the over the air streaming. When my trials run out, I'm killing it and just keeping the app access.
The following 2 users liked this post by biggator6:
Hirohawa (08-29-2018), SRQ Vette (08-31-2018)
Old 08-29-2018, 05:33 PM
TorchRedFred
I purchased the XM tuner and tried it. I ended up cancelling because I found the reception to be so poor that I couldn't enjoy it. I have Sirius in my daily driver Ram 1500 and use it all the time, but in the Corvette I have had no luck getting good reception even with the Pioneer.
Old 08-29-2018, 05:35 PM
TorchRedFred
Good to know.
Old 08-29-2018, 07:28 PM
Hirohawa
Hirohawa's Avatar
I didn't even realize there was an XM app. Like I said total Newb. So if you use the app you don't need the hardware I assume?
Old 08-29-2018, 09:24 PM
jumpinjer
jumpinjer's Avatar
Great info here, guys. Thanks!
Old 08-29-2018, 10:30 PM
CrystalRedTed
I just tried out the app as well (free preview) and it is dramatically better. The app also integrated nicely into CarPlay although there were buffering delays. It's definitely the way to go if you have good cellular coverage and a good plan. There is still some weird stuff going on - some sort of odd EQ applied that tends to make the 80-100Hz bass sound sloppy and over pronounced. I cleaned it up a bit by messing with my crossover frequency and sub volume, but it still didn't seem to sound as good as either Pandora or Apple Music. I could probably get it close by playing with it some more. I won't bother though. XM Streaming pricing seems overly ambitious compared to other options so I don't know why anyone would subscribe unless there were some particular content that they really wanted.
Hirohawa (08-30-2018)
Old 09-29-2018, 01:12 PM
Hirohawa
Hirohawa's Avatar
If I were to get an amp and Subwoofer would I need a Optima Yellow top or would a normal Red top work?
Or just as is - will a Red Top be OK with the new headunit and speakers.
Old 09-29-2018, 03:56 PM
Pb82 Ronin
Pb82 Ronin's Avatar
I run a stock battery and alternator with a 10W7 and 2 amps...no issues.
Hirohawa (09-29-2018)
Quick Reply: New Head unit - do I need to redo all speakers?
