Sponsored by: Innova
C6 amp replacement
Old Sep 5, 2018 | 02:39 PM
biggator6's Avatar
biggator6
Default C6 amp replacement
Seeing the thread with the 'stealth' install (where he put the arc audio amps in the factory location) got me thinking.
Has anyone compiled a list of amps that can fit in the factory location? I know there are a bunch of small class D amps around now.. but curious if there's a list.
Old Sep 5, 2018 | 06:09 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
No list here. But I'm going to put a pair of Soundstream Picasso Nano PN4.1000 in its location.
Old Sep 6, 2018 | 08:38 AM
Smokeyjr's Avatar
Smokeyjr
Emerging Vendor
yes...I have one and used it...it is a ARC Audio KS125 4 mini...it is the best out there and fits in the cavity sir...and I may possibly be selling it along with the ARC AUDIO sub BASS amp
Old Sep 6, 2018 | 10:01 PM
biggator6's Avatar
biggator6
Maybe I missed it.. but is there even a good measurement of how much space is available to work with? Size of the old amp?
There seems to be a lot of good options for small amps, but it's looking like it'll require two small ones to power components and a sub.
Old Sep 6, 2018 | 11:01 PM
Smokeyjr's Avatar
Smokeyjr
Emerging Vendor
not my friend with a arc audio...they are built for power...more power than you will ever need...but always have it when you want it,,,there is a thread out there that has it installed...one of the best imo
Old Sep 6, 2018 | 11:29 PM
biggator6's Avatar
biggator6
isn't that limited to 4ohm bridged? So if I ran it as a 3 channel, the bridged sub channel would be 4ohm.. was looking at the NVX loaded stealth sub box, which is 2ohm (and why I was assuming I'd need a separate amp for the sub)
Would love to just run a single amp with 2 channels for components and 2 channels bridged/mono for the sub... and still fit it in the stock location.
Old Sep 11, 2018 | 05:10 PM
endus's Avatar
endus
Got a link to the other build thread with the amps in the factory location?
I shouldn't have started poking around the audio forum...I *was* satisfied with just doing the head unit...
Old Sep 12, 2018 | 02:12 PM
biggator6's Avatar
biggator6
Found the thread
https://www.corvetteforum.com/forums...rade-pics.html
To C6 amp replacement
