Sponsored by: Innova
PAC OEM 1 Question....need help
Old Oct 26, 2002 | 01:41 PM
USMUSCL's Avatar
USMUSCL
St. Jude Donor '05
Default PAC OEM 1 Question....need help
Hey
got my OEM 1 yesterday and says the red wire must be connected to a switched ignition....where did you guys connect this to?
Picsa or explination would help a lot!!!
Old Oct 26, 2002 | 01:53 PM
TheWacoKid's Avatar
TheWacoKid
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: PAC OEM 1 Question....need help (USMUSCL)
A switched ignition is just a fancy way of saying, "when you turn the ignition on, this line is hot." I don't have a vette, and my dad won't let me rip into his, but you can probobly just tap in to the radio harness. Again, this is a generalized answer, so be warned, it may not work on a vette.
Old Oct 26, 2002 | 01:55 PM
USMUSCL's Avatar
USMUSCL
St. Jude Donor '05
Default Re: PAC OEM 1 Question....need help (TheWacoKid)
it says the factory audio connector does not have a switched ignition source...
that mean anything to you?? :confused:
Old Oct 27, 2002 | 10:54 AM
TheWacoKid's Avatar
TheWacoKid
Not sure, but I think it may not have a switched power source because the radio will stay on till you open the doors, even after you take the key out...but I can't go out and look at my dad's car, so I can't help any more than that. Just post a new thread "Switched Ignition" and ask were to find one....someone will know.
Sorry I can't help!
[Modified by TheWacoKid, 9:57 AM 10/27/2002]
Old Oct 27, 2002 | 11:37 AM
carrerarod's Avatar
carrerarod
Probably several way to do this. basically you are looking for a wire that is only hot when the ignition is switched on. Fuse box is a good candidate. Look for the accessories fuse for one. or you can tap into the ignition switch itself. I think it has a 20 amp fuse and uses about 10 amps so as long as the OEM-1 thingie draws less than 10 amps..... :yesnod:
Old Oct 27, 2002 | 02:41 PM
aurik's Avatar
aurik
Cruise-In IV Veteran
Elite Member
Default Re: PAC OEM 1 Question....need help (carrerarod)
There is an accessory power adapter in the passenger footwell, which people often use to hardwire their V1's to... http://frankhunt.com/FRANK/hobbies/c...e_install.html
Old Oct 27, 2002 | 05:27 PM
USMUSCL's Avatar
USMUSCL
St. Jude Donor '05
Default Re: PAC OEM 1 Question....need help (aurik)
Thanks for the Help....Conquer told me to run a wire to the passenger fuse box and plug it in to fuse number 18.
Thanks again for the help!!!
To PAC OEM 1 Question....need help
