C6 Audio Upgrade Recommendations
I recently bought a 2007 Callaway convertible with NAV and XM. I'm looking for options to upgrade the audio system. About 8 years ago, I swapped the in-dash changer on my 2008 coupe for an aftermarket GPS head unit, so I have some hands-on skills. Much has changed in those years, and I'm looking for recommendations. I'm pretty open to suggestions. At a minimum. I want iPod control and charging with the use of steering wheel controls on the existing head unit. I'd also consider a head unit swap with bluetooth calling, audio streaming, and steering wheel controls. I'd prefer to use the existing microphone, Audio via SD card is a definite plus. I love the Uconnect in my 2015 Grand Cherokee. Comments?
Also, just for reference sake, here is all the things I purchased for my install.
Copied and pasted from one of my previous posts:
Here is all the stuff I bought for my install. The Pac Audio harness/interface works with and/or without Bose systems. The installation gear is the same regardless of what brand head unit you buy. In my case I went with the Pioneer 8200nex. I got the head unit and all the installation gear from Amazon.
1- Pac Audio RP5-GM11 wiring harness with steering wheel controls (RP4-GM11 is also compatible and an alternative to the RP5)
2- Metra 95-3304 double din face plate
3- Sirius XM SXV300v1 tuner (optional if you want Sirius XM) and Sirius XM 10ft antenna ext. cable (if u want to re-use factory antenna)
4- Pyle PCNM38FRV back up camera (was only $17 but works great)
5- A pack of crimp style cap connectors 22/18 gauge and a crimp plier (since I didn't have one)
You can re-use the existing XM antenna with the cable mentioned but I just want to mention that my SiriusXm reception still stinks.
Do it yourself thread with pictures done by former forum audio vendor:
https://www.corvetteforum.com/forums...is-to-diy.html
Update: I have since cancelled my SiriusXm subscription because of reception problems in my Vette. I now use the SiriusXm app through my phone and Apple CarPlay. Works much better. My suggestion is skip the SiriusXm tuner and antenna and go with the app through your phone instead if you prefer to have SiriusXm. (*** Data charges may apply if you don't have an unlimited phone plan)
