Sponsored by: Innova
Audio woes
Old May 17, 2019 | 09:34 PM
UmX's Avatar
UmX
Default Audio woes
So i ripped out the bose system amp and speakers... I replaced fronts with 6.5s comps and 5.25 in the back and a fosgate 300x4...........The rear speakers i just ran leads from the speaker to the amp the front i tapped into the harness that went into the bose amp..
Now when the car is not running everything plays no issues whats so ever, when the car is running the speakers pop and cut out randomly.
i also have a post trying to figure out whats up with the charging system as well.. But the charging system issue came up when i installed all this stuff as well it didnt happen before. I actually un hooked everything to rule it out.. radio was unhooked, the power and grounds going to the amps and the front speakers were d/ced and still had the charging issue. Is possible what ever is going on with the charging system is causing issues with the audio play back as well?
this is the other thread if you want more back story and troubleshooting i have done
https://www.corvetteforum.com/forums...post1599420366
Old May 30, 2019 | 01:59 PM
htown81vette's Avatar
htown81vette
I used to have these problems until i quit being a cheap *** and started buying the amp wiring kit. It comes with everything you need, shielded cables, ground wires, fuses etc etc.
This one is rated for 1,000 watts, but I got a 600W kit for about $100:
https://www.sonicelectronix.com/item...NVX-XAPK0.html
Old Jun 10, 2019 | 07:21 PM
VinceC5's Avatar
VinceC5
Did you figure this out?
Old Jun 10, 2019 | 07:27 PM
UmX's Avatar
UmX
The 4 rib belt trying the accessories side on my sec drive kit was slipping causing issues.
Old Jun 11, 2019 | 12:45 PM
Pb82 Ronin's Avatar
Pb82 Ronin
A slipping belt caused all the audio issues too?
Old Jun 11, 2019 | 01:39 PM
UmX's Avatar
UmX
Yes sir. Gotta love electrical
Old Jun 18, 2019 | 12:34 AM
Legionofone1's Avatar
Legionofone1
It was causing the alternator to vary its output and surge probably.
To Audio woes
