Sponsored by: Innova
powering a small amp
Old Jun 27, 2019 | 08:27 AM
mfi2000's Avatar
mfi2000
Default powering a small amp
Im going to add a small Alpine amp to an Alpine head unit. Its made for the head unit but needs 15 amps. Is there a spare fuse in the foot well fuse box I could use.I'm checking the fuse layout but don't see anything. If not, run it to the battery.
Old Jun 27, 2019 | 12:12 PM
mfi2000's Avatar
mfi2000
Battery it is.......
Old Jun 27, 2019 | 12:52 PM
mfi2000's Avatar
mfi2000
But...what about tapping into the the center console power supply fuse with an add a fuse...only need 15 amps.
Old Jun 27, 2019 | 03:52 PM
Pb82 Ronin's Avatar
Pb82 Ronin
What amp are you running that only requires 15 amps?
Old Jun 27, 2019 | 04:34 PM
mfi2000's Avatar
mfi2000
Alpine kt445A..it plugs into the headunit and doubles its power to about 40 watts..its not the usual kind that you hook up anything to.
Old Jun 28, 2019 | 12:06 PM
GCG's Avatar
GCG
@mfi2000 No need to do any of those things. There's an unused harness (except '04) in the passenger's footwell that has 3 wires (yellow: switched via Fuse 11, orange: always hot via Fuse 7 and black: ground).
Old Jun 28, 2019 | 06:24 PM
mfi2000's Avatar
mfi2000
Ok..ill check it out..wired everything up and...i have to cut the damn metal bracket in the back so the radio will fit..oy
Its always something..
Old Jun 28, 2019 | 06:27 PM
mfi2000's Avatar
mfi2000
fits right in area below hvac controls
Old Jun 28, 2019 | 07:20 PM
GCG's Avatar
GCG
Let me know how it goes
Old Jun 29, 2019 | 10:08 AM
mfi2000's Avatar
mfi2000
Cant finish till next week..On way to VT..
One thing will be interesting..the amp has gain controls and the metra adapter has them too..should be fun setting them
So it sounds right..
Old Jun 29, 2019 | 11:26 AM
mfi2000's Avatar
mfi2000
And just thought of this..Found the wires cut to the outlet in the armrest..guess someone could not figure out how to remove it..i can tap into that wire for the amp and use the footwell one for my gps..they sell a hardwire cable for this..would be nice to get that mess away from the ashtray area.
To powering a small amp
