Sponsored by: Innova
5 channel amp
Old Aug 6, 2019 | 09:10 PM
KT35's Avatar
KT35
Default 5 channel amp
https://www.amazon.com/gp/product/B07NSBRSFN/ref=ox_sc_act_title_5?smid=ACY16S668WPB2&psc=1 https://www.amazon.com/gp/product/B07NSBRSFN/ref=ox_sc_act_title_5?smid=ACY16S668WPB2&psc=1
Anyone use this amp?
Looking to change all my speakers.
Old Aug 7, 2019 | 08:58 AM
KT35's Avatar
KT35
Or have any other recommendations for a 5 channel amp in the 300 to 500 dollar range.
Going to go with the Kenwood 8905 H/U.
Old Aug 7, 2019 | 09:01 AM
Pb82 Ronin's Avatar
Pb82 Ronin
I don't have any experience with that exact amp. But there are more powerful ones for a bit more money. What speakers you're trying to power is normally what drives amp selection. That being said, what is your speaker setup?
Old Aug 7, 2019 | 10:02 AM
KT35's Avatar
KT35
PB82,
Here is what I'm looking at. I'm open to suggestions too.
https://www.amazon.com/gp/product/B00DH2XYSI/ref=ox_sc_act_title_6?smid=A1FMHNVWMGI839&psc=1 https://www.amazon.com/gp/product/B00DH2XYSI/ref=ox_sc_act_title_6?smid=A1FMHNVWMGI839&psc=1
https://www.amazon.com/gp/product/B075ZHJ683/ref=ox_sc_act_title_5?smid=A1FMHNVWMGI839&psc=1 https://www.amazon.com/gp/product/B075ZHJ683/ref=ox_sc_act_title_5?smid=A1FMHNVWMGI839&psc=1
https://www.amazon.com/gp/product/B01GSFIVHY/ref=ox_sc_act_title_10?smid=AFD3YB3MPK3U3&psc=1 https://www.amazon.com/gp/product/B01GSFIVHY/ref=ox_sc_act_title_10?smid=AFD3YB3MPK3U3&psc=1
KT
Old Aug 7, 2019 | 10:24 AM
Pb82 Ronin's Avatar
Pb82 Ronin
Well the good news is the amp you chose will drive your speaker selection beautifully. It's not enough amp for the sub though. That's a 500W RMS sub, and your amp will only push 300W RMS to it. Does that mean you "shouldn't" run that amp? Not at all. You wont hurt a thing. That's the good news. The bad news is you'll never drive the sub to it's normal power level. For some people 300W on a 12 is plenty. This could be enough for you. Only you will know that answer.
If you're willing to spend a bit more, I would look into this AMP. It's perfect for the components you listed and it's a remarkable amp. I'm not sure what your budget is. Also, are you wanting Infinity for a particular reason? They're not a bad choice, but there are alternatives out there that can outperform them.
Old Aug 7, 2019 | 10:51 AM
KT35's Avatar
KT35
I've always been a big fan of infinity speakers but not set on them. If you have other recommendations please send them my way.
Old Aug 7, 2019 | 11:22 AM
Pb82 Ronin's Avatar
Pb82 Ronin
For a C5? $3-500 per set? Or total?
Old Aug 7, 2019 | 11:34 AM
KT35's Avatar
KT35
C5 300-400 total.
Old Aug 7, 2019 | 12:22 PM
Pb82 Ronin's Avatar
Pb82 Ronin
That's a bit tougher to do. But I could see being happy with this setup: (You didn't mention ZO6 or coupe, and those speaker sizes are different)
https://www.ebay.com/itm/Focal-Acces...kAAOSwLr1cUc9c (These are $400 retail)
https://www.ebay.com/itm/FOCAL-5V324...cAAMXQeKNTMzZc (A good 5.25" woofer)
https://www.ebay.com/itm/SUNDOWN-AUD...AAAOSwCU1Yyw3q (If you're not going to run a separate subwoofer, run these as subwoofers. Make sure to add deadening all around these things though.)
Old Aug 7, 2019 | 02:47 PM
KT35's Avatar
KT35
It’s a z06
Looking to run a separate sub too.
Recommendations on the sub?
Old Aug 7, 2019 | 03:15 PM
KT35's Avatar
KT35
I will try and get the focal rear and front components.
Any other amp recommendations? 1100 is a bit more than I want to spend.
Old Aug 7, 2019 | 04:00 PM
Pb82 Ronin's Avatar
Pb82 Ronin
http://www.jlaudio.com/rd900-5-car-a...plifiers-98642
Same class amp...just not as pretty or compact. But same amp guts, just a little less power with the 4 ohm speaks.
Subs are really up to you man. There isn't really a "bad choice" per se.
Old Aug 7, 2019 | 08:02 PM
KT35's Avatar
KT35
Thanks PB82. I will start acquiring parts.
I'm in the process of putting a clutch in the car as we speak.
Old Aug 7, 2019 | 08:35 PM
KT35's Avatar
KT35
What wire harness did you buy to hook up new headhunt not using any of the stock speakers or amps?
Old Aug 7, 2019 | 09:51 PM
Pb82 Ronin's Avatar
Pb82 Ronin
Call Crutchfield. They have everything you need to get a HU into your car with the correct harness. There are literally MILLIONS of harnesses.
Old Aug 7, 2019 | 10:23 PM
KT35's Avatar
KT35
Last one. What do you think about this?
https://www.pioneerelectronics.com/P...eries/GM-DX975
Old Aug 8, 2019 | 06:58 AM
Pb82 Ronin's Avatar
Pb82 Ronin
That's a solid performing amp, if the numbers are good. Personally, I don't have any experience with it, so I can't give you first hand knowledge as I have on the other items I listed. But all in all, I would definitely run 2 ohm items to max out the power available on that amp...especially the sub. It takes a HUGE hit in power running at 4 ohms.
To 5 channel amp
Old Nov 2, 2019 | 03:04 PM
KT35's Avatar
KT35
Ok mid range speakers ordered.
Focal 165AS component set for the front (6.5)
Focal 130AS for the rear (5.25)
Now I just need to figure out what amp and sub. Need some help. here are a couple of subs and amps.
https://www.sonicelectronix.com/item...VX-VCW124.html
https://www.sonicelectronix.com/item...h-P3D4-12.html
https://www.sonicelectronix.com/item_127719_Kicker-CompVX-CVX124-44CVX124.html
amps
https://www.sonicelectronix.com/item...-VAD11005.html
https://www.sonicelectronix.com/item...l-RD900-5.html
https://www.sonicelectronix.com/item...-SX212006.html
https://www.sonicelectronix.com/item...FPX5.1200.html
https://www.amazon.com/Memphis-Audio-VIV900-5-5-Channel-Amplifier/dp/B072MFKH1C https://www.amazon.com/Memphis-Audio-VIV900-5-5-Channel-Amplifier/dp/B072MFKH1C
I really like the NVX amp and woofer. It has tons of great reviews. Anyone have comments or suggestions? The box I have has a mounting depth of 7.25 and .86 internal sealed box.
KT
Old Nov 2, 2019 | 03:09 PM
KT35's Avatar
KT35
I got the new H/U installed too.
Old Nov 2, 2019 | 04:09 PM
Pb82 Ronin's Avatar
Pb82 Ronin
Really hard to make the choice for you man. If you picked one or the other, you could then pick the ideal alternate part to compliment the chosen selection. When you lay out a bunch of parts, they will all perform tasks similarly. What am I saying? Pick a sub that you like, then match the amp that you need to tie it all in...OR...pick an amp first, then pick the sub that will work best with the amp you chose. Half of the work is done...you have component speakers. Take their RMS power requirement into consideration while selecting a 5-channel. Once you find the amp that best drives your components, take a look at the sub channel and it's specs. Then find the best sub to fit that sub channel. Make sense?
