Sponsored by: Innova
Sub Time
Old Aug 15, 2019 | 04:18 PM
mfi2000's Avatar
mfi2000
Default Sub Time
Just ordered the vettenuts corner box with JL Audio 10W3v3-2. Now I need an amp. Just want to get a mono amp for now. Spoke to Vette nuts and their experience with this sub is that it can't handle 500 watts..300 more like it. Any ideas?
Old Aug 15, 2019 | 04:22 PM
VinceC5's Avatar
VinceC5
Alpine PDX 4.150!
In 3 channel mode.
150 watts per channel to each door (your Focals will love this)
300 watts to the subwoofer.
PM me if interested.
Old Aug 21, 2019 | 07:32 PM
C5wilts's Avatar
C5wilts
I have a cheap *** Walmart razor amp pushing a 12”Kenwood and it hit so hard.
Old Aug 22, 2019 | 02:09 PM
mfi2000's Avatar
mfi2000
Went with a JL 500 watt mono which I'll mount behind the passenger seat.
Old Aug 22, 2019 | 10:53 PM
VinceC5's Avatar
VinceC5
nice choice.
Old Aug 23, 2019 | 07:36 AM
mfi2000's Avatar
mfi2000
Then when I want to really go for it I'll replace that with a 6 channel for the whole thing.
Old Aug 23, 2019 | 10:47 AM
Pb82 Ronin's Avatar
Pb82 Ronin
How are you going to mount the amp behind the seat? Be VERY VERY careful doing anything that involves drill there. The fuel tanks are directly behind the waterfall panel. Any holes drilled there and you WILL rupture the tank...
Old Aug 23, 2019 | 02:53 PM
mfi2000's Avatar
mfi2000
3//4 plywood mounted under the carpet with 3m VB double sided tape. Screw inserts and screw the amp to it...piece of cake.
Old Sep 22, 2019 | 06:36 PM
mfi2000's Avatar
mfi2000
Now the hard part..wiring in the amp..
Old Oct 1, 2019 | 08:17 AM
mfi2000's Avatar
mfi2000
used an old speaker wire that had a pvc coating on it to make a snake to get into the footwell.
pulled the power wire through
the finished wire. It was just stuffed in there and loose out of the box. not going anywhere now
took apart the main fuse an added ferrules to the wire, and techflex covering. everything heat shrinked.
3M VBM double side tape and threaded inserts.
Started on the amp yesterday. Real pain to get the 4 gauge wire through the grommet but figured it out. From there wasn't too hard to get behind the waterfall where the amp will go. Some plywood, double side tape and threaded inserts. Grounded it to the waterfall metal. Now on to the speaker wires and signal wires..then hopefully won't have to touch this again for a while.
Old Oct 1, 2019 | 12:09 PM
Pb82 Ronin's Avatar
Pb82 Ronin
Looking good man.
Old Oct 1, 2019 | 02:50 PM
mfi2000's Avatar
mfi2000
Takes a while though..working inside the car is...fun. I almost gave up trying to get the wire through the dash. Took a ride to a stereo shop..and it was closed..which indicated to me..to keep trying.
Old Oct 1, 2019 | 05:32 PM
dphins's Avatar
dphins
What brand wire are you using? I tried CT Sounds in my vette and it was to flimsy. I had a hard time getting it to crimp.
Old Oct 2, 2019 | 07:23 AM
mfi2000's Avatar
mfi2000
Rockford Fosgate.
These are ferrules that slip over the end of the wire. the amp terminal screw crimps it when you tighten it.
stuff like this: https://www.kinequip.com/products/wa...hoCm9UQAvD_BwE
Old Oct 2, 2019 | 12:05 PM
Pb82 Ronin's Avatar
Pb82 Ronin
Id be interested to hear that sub on a full 500W. I used to run 2 of them on 500W. Still did 128.9 db.
Old Oct 2, 2019 | 01:56 PM
mfi2000's Avatar
mfi2000
Soon as I have some more time I'll finish it. Busy month.
Old Oct 4, 2019 | 06:58 PM
NYC6's Avatar
NYC6
Just put a JL XD600/1v2 on my 10w3v3-2 and turned the power down a little and the bass sounds terrific. Sharp clean hits you can really feel and it keeps up nicely with very fast bass tempo tunes.
To Sub Time
Old Oct 7, 2019 | 09:54 AM
mfi2000's Avatar
mfi2000
Main positive cable with ferrule and techflex covering
Ground with a ferrule and techflex
and the speaker wire
Doing these cables the right way is certainly the loooong way. The ferrules are cool and with the right tool they work great. Putting the techflex covering on adds a good amount of time as you have to scootch it on inch by inch..then heat shrink everything. It does look very good when your done though. Next up is pull the radio again and hook up the amp turn on and the signal cable. Then I can get the whole thing tuned up.
Old Oct 7, 2019 | 10:48 AM
Pb82 Ronin's Avatar
Pb82 Ronin
Very nice work man. Wiring makes all the difference.
Old Oct 7, 2019 | 11:12 AM
mfi2000's Avatar
mfi2000
Takes forever..probably why most people just run them as is.
