Sponsored by: Innova
Frequency Response
Old May 10, 2020 | 02:51 PM
rcopeland's Avatar
rcopeland
2nd Gear
Default Frequency Response
Does anyone know what the frequency response range is on the front 6 1/2" speaker for a 2006 C6?
I only want to replace it with one that will output more bass (lower frequency range). If you know the back speaker's frequency, that would be nice to know too.
Old May 10, 2020 | 08:15 PM
VinceC5's Avatar
VinceC5
Stock systems come with either an 8" or 10". The amp and speakers are matched, replacing just the speaker will not get you the results you are after. Easiest way to get more bass is to add Dynamat to your doors or a powered subwoofer in the back.
Old May 11, 2020 | 11:19 AM
Pb82 Ronin's Avatar
Pb82 Ronin
Should be a 10" driver up there. And the freq response is is 15 Hz- about 5K Hz. But what you actually hear is about 600-3K Hz because BOSE IS GARBAGE!!!
If you can't tell, Bose doesn't get much love around these parts. Welcome to the Forum BTW.
Old May 12, 2020 | 12:36 PM
rcopeland's Avatar
rcopeland
2nd Gear
Thanks guys, I appreciate the info.
To Frequency Response
