Hi all, I am brand new on here and hope someone else has dealt with the problem I am having. I had the check engine and TMPS error lights on. I replaced the computer on the car which resolved the check engine light and new tire sensors were installed. I was told that I need a new TPMS/keyless entry receiver module which is no longer made so I am forced to get used. I bought one and it didn’t solve the TPMS error.
I would like the keyless entry to work but I am told that the the fob must me directly matched to the module. It just seems hard to believe that if someone has a bad module that there would be no solution. I was wondering if there could be an aftermarket solution as an alternative. I hope someone can offer some guidance. Thanks In advance!
New FOB needs to be programmed, Did you do that? Good instruction here
For the TPMS; each sending unit in each tire needs to be "learned" by the car. Procedure here the magnet can be any large magnet, like a magnet from a speaker.
Let us know if you are talking about something different.
