Sponsored by: Innova
C6 vert suggestions
Old Jul 23, 2020 | 09:27 PM
mobyred99's Avatar
mobyred99
Cruising
Default C6 vert suggestions
Have a 2010 GS vert 4LT that I would like to upgrade the head unit at least. I would need the ability to play CD’s, Bluetooth, nav or Apple Car play. Also don’t want to spend a fortune.
TIA
Old Jul 24, 2020 | 12:53 AM
madsonp's Avatar
madsonp
I suggest you start looking here. https://www.crutchfield.com/g_182350...FFSize|Double- Find one that has all the features you're looking for in the price range you want to pay. I personally prefer Pioneer myself. One thing to note about Crutchfield is their "What Fits Your Car" search, is that it isn't accurate, it may say certain models won't fit, which isn't correct, any double DIN unit should fit.
Old Jul 28, 2020 | 12:21 PM
Pb82 Ronin's Avatar
Pb82 Ronin
Define "fortune." Much easier to source a good HU when you know what kind of budget you're working with.
Old Jul 28, 2020 | 04:05 PM
mobyred99's Avatar
mobyred99
Cruising
Under say 500.00
Old Jul 29, 2020 | 01:07 AM
madsonp's Avatar
madsonp
Originally Posted by mobyred99
Under say 500.00
$500 isn't going to get you much, personally, I'd suggest spending some more, and getting a better quality head unit. On top of that expense, you'll also need to get an interface, this being the most commonly used one https://www.crutchfield.com/p_541RP5...Interface.html Then you'll also need to get dash kit https://www.crutchfield.com/p_120953...-Dash-Kit.html And while you have everything apart, I highly recommend also installing a backup camera, I'm sure you'd regret not doing it later. Let us know on what you decide for a head unit, there maybe a few other tips and tricks we can offer to help with the install depending on what you get.
Old Jul 29, 2020 | 08:12 AM
mobyred99's Avatar
mobyred99
Cruising
Thanks for the info.
Old Jul 30, 2020 | 09:08 AM
Callaway DrDon's Avatar
Callaway DrDon
Default try this
https://www.corvetteforum.com/forums...ggestions.html
This should be quite helpful, and answer a lot of your questions.
To C6 vert suggestions
