Sponsored by: Innova
RPM5-GM11 Need help
Old Sep 2, 2020 | 11:23 PM
itznemix's Avatar
itznemix
Default RPM5-GM11 Need help
Hey Forum,
I have a 2010 GS Nav unit with bose, Do i connect the colored wires color to color with the wiring harness to my new aftermarket HU? is there anything special i have to do? New to having to hook up audio equipment so i've been struggling trying to put everything together. any photos or videos would be extremely helpful.
Old Sep 2, 2020 | 11:36 PM
itznemix's Avatar
itznemix
Also how in the hell do i turn the dial on the PAC so i can change the number setting to reflect the Sony HU i have.
Old Sep 3, 2020 | 02:27 PM
VinceC5's Avatar
VinceC5
Use a small flat blade screwdriver to turn the ****. Matching colors works most of the time, but consult the manual. It's available online.
Old Sep 3, 2020 | 02:33 PM
itznemix's Avatar
itznemix
Got everything but now no sound is playing . Wired everything corrected .
Old Sep 3, 2020 | 03:46 PM
TorchRedFred's Avatar
TorchRedFred
Did you connect the remote/amp turn on wire?
Old Sep 3, 2020 | 04:33 PM
itznemix's Avatar
itznemix
Got the sound now I find out the dash doesn't fit lol!
Old Sep 3, 2020 | 04:41 PM
TorchRedFred
Should fit. All double din head units should fit. Did you buy the correct radio bezel kit?
Old Sep 3, 2020 | 04:45 PM
itznemix's Avatar
itznemix
I just bought what the sound guy recommended, it has claps on the side that don't go in.
Old Sep 3, 2020 | 05:26 PM
TorchRedFred
Metra 95-3304 is the correct bezel for the C6.
Amazon Amazon
Old Sep 4, 2020 | 01:56 PM
Pb82 Ronin's Avatar
Pb82 Ronin
Pics would really help if you're truly stuck...
Old Sep 4, 2020 | 02:02 PM
itznemix's Avatar
itznemix
Sorry ! I ended up figuring it all out I was just over thinking things , and dealer sold me the wrong kit so once I got the right kit everything was easy. I usually pay for installs but I quoted 3 weeks until anybody could get me in.
Old Sep 14, 2020 | 01:39 PM
Orange Flash's Avatar
Orange Flash
Cruising
Default PAC vs. Metra/Axxess HeadUnit Integration
Hello everyone, I'm new to this forum and have been reading a lot about replacing my factory radio head unit. I have a 2008 Base with Bose/Navigation and would like to install a new head unit that will keep all of the "factory" functions in the car i.e. chime on speakers, OnStar and SWC. From what I have read, most seem to use the PAC RPM5-GM11 but this unit does not keep the factory chimes, if I read it correctly. Has anyone looked at other PAC units or any of the Metra/Axxess units? There seems to be a lot of different units from each manufacturer and it is a bit dauntiung! Thanks for any help! ( Also, If I'm posting this to a wrong forum, please forgive)
Old Sep 14, 2020 | 01:53 PM
Pb82 Ronin's Avatar
Pb82 Ronin
Not in the wrong forum...you should just start your own thread. You'll get far more views/responses/help.
Old Sep 14, 2020 | 02:22 PM
Orange Flash
Cruising
Thanks! I will find out how to create a new thread.
Old Sep 14, 2020 | 02:40 PM
itznemix's Avatar
itznemix
Hey, do you know any forum members who can make sub boxes for the C6 convertible?
Old Sep 14, 2020 | 03:46 PM
Pb82 Ronin's Avatar
Pb82 Ronin
Forum members? @madsonp He's the only one that I know of.
Old Sep 14, 2020 | 04:07 PM
TorchRedFred
Orange Flash, the Pac RP5-GM11 does retain door chimes. It has a small sound box with a volume dial for door/warning chimes. It's not exactly factory, since the factory chimes went through the factory head unit and speakers, but it replaces and supplies the chimes. The sound box gets buried behind the head unit with the Pac harness, so you will never see it. Also, turn the volume down as low as possible because most complain it's a little too loud.
Old Sep 14, 2020 | 08:49 PM
Orange Flash
Cruising
Thank you for the info! I was hoping to find a unit that would direct to the speakers in the car, but it sounds like that is going to be a no starter...Has the unit been reliable? Thanks!
To RPM5-GM11 Need help
