Thinking this over----If i use the antenna wire, wouldn't the amps only be on when the radio is in use?
If i switch to USB music or similar...would the antenna wire/ amps be turned off because the radio is off.??
I posted this when I installed a Pioneer 8200BT 1. Connect the Metra Harness to the Pioneer Harness. The Metra directions are sparse but the EIA color codes match PERFECTLY to the pioneer wires. These are the wires you connect: a. 8 speaker wires (colors matched exactly), b. Red to Red (accessory power) c. Yellow to Yellow (battery/constant power) d. Black to Black (ground) e. Orange to Orange/White (illumination) f. Blue/White to Blue/White (amp turn on/remote on)
depends on how they implemented it. just use a voltmeter to test it out first.
I was hoping you figured this out. I have the same issue. My new head unit only haze a blue wire and I have it connected to the PAC unit blue wire and it sounds Terrible.
Originally Posted by Redd2002
Both the Blue Antenna wire and the switched 12v wire will activate the Bose door amps..thank you
I have decided to do away with all the factory speakers..i started a new thread with questions about the wiring for new speakers
