Alternator and amps?
Redoing some parts of my sound system and can use some suggestions if you will. It’s an 06 Z51 car which has the 145amp alt I believe.
Currently it has two amps running things, a JL 450/4v2 and a HD600/1 on the 10w3v3. The alternator in the car is original and it’s long in the tooth and voltage drops lower currently then I would like with the amps now. I’m replacing the 450/4 with an audiocontrol LC- 4.800 next week which will run front Hertz components and Morel Tempo ultra coax rears. Fronts will be getting about 120w each and rears about 100w each.
Time to upgrade the alternator. While surfing around I pretty much decided on the Mecham and question is, the 170 or the 240 amp unit? I learned here that the stock C6 systems need 40amp to run all its necessary bits and in addition to that I have a B&M fanned trans fluid Cooler which draws 15A and the audio control amp which is fused with two 40A and one 50A on the JL mono amp. That there adds up to 185A. The car is SC’d and runs hotter then a stock C6 so the fan runs at a higher percentage.
I understand the 170A version alternator charges better at a lower RPM which is good for my region, getting stuck in NY traffic or sitting in a mall parking lot while the wife does her shopping or whatever but will a quality 170A alt be able to keep my electrical system healthy? Or should I bolt on the 240A? thanks
I’ll also be doing the big 3 at the same time as the alt.
