CD Cassette Has CD ERR
I have a CD cassette problem. First time I have tried to use it and it seems like a CD that was playing does not want to eject back into the cassette, and now nothing plays and there is an ERR message. Ideas???
As with any electrical glitches with these cars, the first thing I'd recommend doing is to either disconnect the battery for a short period of time, then reconnect it, or try pulling the fuse for the radio then put it back in, and see if that does anything for you. If that doesn't do it, you'd probably have to send the unit in to have it repaired, if that's the case, I'd suggest just replacing it with a good after market system, you'd be glad you did in the long run sound and functionality wise.
