Sponsored by: Innova
Kenwood firmware update failed
Old Jun 16, 2021 | 12:24 AM
208vette's Avatar
208vette
Default Kenwood firmware update failed
I have a Kenwood DMX957XR and just tried to do a firmware update. Ive had the unit for about a year and never updated it, fearing exactly just what happened. The unit is stuck in a rebooting loop saying it can't read the data. I've tried two different usb drives, completely erased and reformatted. They are a few years old, so I'm going to go pick up a new one or two tomorrow. Read one post where a guy went thru five different usb drives to get it to work. I've tried reformatting in each type of FAT format... ex, 32, and ntfs. Even tried taking the files out of the main folder. Nothing is working.
Anyone been down this road? How did you get it resolved? Is there a hard reset button holding technique to get the headunit out of the loop. Tried searching a didn't come up with anything on that either.
Old Jun 16, 2021 | 07:26 AM
tcfamy's Avatar
tcfamy
Veteran: Coast Guard
Went down this same path on a DNX997XR. I had two steps that made the difference. First reformat your usb with a full (not quick) format to FAT(deault) format. Second, when you unzip the download file, unzip it directly to the target usb drive. Don't copy it over from another folder.
Not sure why this worked, but it loaded up on the next try.
Tom
Old Jun 16, 2021 | 11:46 PM
208vette's Avatar
208vette
Tom
Thank you Tom. I did this for the most part and it worked. Only thing different was I used a brand new, never used usb drive. 16gb Memorex brand from Target for $7. I did not format it, it was already in fat32. I unzipped the files directly to the usb drive and it worked on the first try. The ones I used previously were pretty old, one of them might be 10 years old, the other at least 5 or 6. Apparently the Kenwood headunits are very picky about what used to be on the usb drive even if it was re-formatted.
Old Jun 25, 2021 | 01:10 AM
LSgoBRRR's Avatar
LSgoBRRR
I doubt that mattered if you were able to read/write the files on the computer, USB flash memory degrades from writing mostly, you loose sectors/capacity slowly. I also doubt zipping vs. copy/paste made a difference either so long as the write process finished and you got everything. Probably the full FAT 32 formatting that fixed it.
Old Jun 25, 2021 | 01:42 AM
208vette's Avatar
208vette
I did try a full format, not quick, in fat32 with the older usb drives, but it still wouldn’t work for me. Just glad that worked with the new ones. CarPlay is working a lot quicker and more stable than before.
To Kenwood firmware update failed
