C6 Bose system- Speakers stopped working
Everything has been working flawlessly for the past 2+ years. My wife was driving the other day and the sound cut out and was completely dead.
Now when you turn the car on, the speakers make some clicks, then again no sound and the rest of the ride there will no side.
Otherwise the headunit still operates as it should. I verified all the wiring is still good and intact. I checked all fuses and they all are still fine.
I think my next step is to replace the Bose amp. Is there any way to test if the amp is dead?
See if Dr Don can give you some hints about testing the amp.
you can also just try the oem radio to see if it works with the amp.
Sure, it would be a hassle to pull the Kenwood and reinstall the stock head unit, but since you didn't see anything obvious with the interface wiring, I think this would be the best way to test the amp without pulling it out and sending off to someone. If it works after doing so, then I would suspect your interface is bad which has been known to happen with some of these. Out of curiosity, which interface did you use in your car ?
Changed the Bose amp out for a known working one and the sound is back.
I put some heat reflective tape on the floor under it. My thoughts, after the long tube install more heat was getting into the foot well and maybe that pushed my stock amp to an early grave.
