Sponsored by: Innova
Sub commong tomorrow
Old Dec 22, 2002 | 11:03 AM
Son93SL2's Avatar
Son93SL2
Default Sub commong tomorrow
I'm way way too excitied. I have been without my sub for 3 weeks now. :cry
Do I really have to break in the sub?
Old Dec 22, 2002 | 11:09 AM
TheWacoKid's Avatar
TheWacoKid
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Sub commong tomorrow (Son93SL2)
You should play it low to moderate volumes for the first 15-20 hours or so to break in the suspension. You will notice a huge difference once it loosens up. You could play it loud at first, but it will sound kinda bad. It is just better to break them in like a car engine. Gentle for a little while, then pound them. :cheers:
Congrats on the sub. What kind did you get?
Old Dec 22, 2002 | 11:25 AM
Son93SL2's Avatar
Son93SL2
Default Re: Sub commong tomorrow (TheWacoKid)
Ok, i'll break her in in one day then. :)
I got this little bad boy.
12w3v2-d2
Old Dec 22, 2002 | 11:40 AM
DC5's Avatar
DC5
sweet! My 12w3v2-d4 is scheduled for delivery tomorrow also. I'll be driving it with a 500/1. Can't wait. What kind of enclosure do you have?
Old Dec 22, 2002 | 01:20 PM
Son93SL2's Avatar
Son93SL2
Default Re: Sub commong tomorrow (DC5)
What Ohms are you planning on running your sub at and how many ohms is that 500 watts at?
I have a 1.25 ft^3 with a sloped front. I just finished sealing the interior of the box so now the enclosure is a bit tighter.
I am going to push 375 watts at 4 ohms to my sub wired at 4 ohms. :)
Old Dec 23, 2002 | 10:35 AM
leolufse's Avatar
leolufse
I just picked up 2 JL 10W3v2-D2s. I put each of them in their own sealed enclosure at .65ft^3. I wired the voice coils in series to give each sub a 4 ohm impedance. I'm running them from a MTX 6500D mono sub amp at about 800 watts at 2 ohms. So each of the subs is getting about 400watts. I'm still breaking in the subs right now, but will all that juice, they don't need to move very much to pound. :smash:
Old Dec 23, 2002 | 10:45 AM
DC5's Avatar
DC5
I'm planning on wiring the single 12w3v2 D4 in parallel for a 2ohm load for the JLAudio 500/1. This will be my first JLAudio amp (I've also got a 300/2 ordered for the front speakers) and it has some type of variable regulator for the ohms in addition to the voltage. My understanding is that from 1.5-4 ohms, this amp will deliver 500w. I haven't yet started to build my cabinet. I had better get busy. :cheers:
Old Dec 23, 2002 | 11:20 AM
leolufse's Avatar
leolufse
Yes you are correct about the 500/1 amp. 500watts at 1.5-4 ohms. So if you ever wanted to add another 12w3v2 D4, just wire both subs in series for an 8 ohm impedance per sub. By hooking up two 8 ohm subs to a mono amp, it will "see" a 4 omh load. That will be 250 watts for each sub, not too shabby.
[Modified by leolufse, 11:22 AM 12/23/2002]
Old Dec 23, 2002 | 01:03 PM
DC5's Avatar
DC5
Default Re: Sub commong tomorrow (leolufse)
:thumbs:
Old Dec 23, 2002 | 02:20 PM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
Yeah, in essence they are wired series/parallel since they're hooked to a mono amp. Just in case anyone is interested.....if you don't have a mono sub amp and if your amp handles 2-Ohm MONO not stereo, you could just wire the subs series/parallel yourself by wiring the 2-Ohm DVC's in series to 4-Ohm and then the two subs together in parallel (bridged) to the amp leaving a 2-Ohm mono load on the amp. If you had 4-Ohm DVC's you could wire them in series to 8-Ohm then the subs together in parallel to the amp for a 4-Ohm mono load. This last Ohm configuration is better for amps not designed for a 2-Ohm mono load, which most non-mono amps aren't.
Just a little FYI for any who want to know. :seeya
To Sub commong tomorrow
